GLB Class (X247) Produced 2020 to Present
Is there a GLB SERVICE SHEET
Old Jan 10, 2023 | 04:06 AM
SRNH's Avatar
76 240D RIP, 79 240D RIP, 14 ML350BT-GONE, 22 GLB250-GONE, 24 GLC300, 26 GLC300 (on order)
Just getting my records together for the new/used '22 GLB250 4matic. I'm a tad-bit **** retentive about tracking scheduled maintenance and all the accumulative costs, this GLB replaced a '99 Lexus RX300 I purchased new and I could tell you that during the course of ownership I spent a total of $13,850. on maintenance and miscellaneous. I also have a detailed spreadsheet for my '14 ML350 with 56K miles. The reason for this post, I was pretty surprised at the format of the "Service Information" booklet included with the Owner's Manual packet, more like a discover and record approach. anyway, I've attached my ML350 Service sheet, has anyone found something similar for the GLB. Thanks.............
I SEE THE ATTACHMENT FUNCTION ISNT WORKING FRO A PDF i WILL ATTACH SERVICE SHEET LATER
Old Jan 10, 2023 | 07:23 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Unfortunately I could never find complete Service Information for GLB. The only references are to Schedule A and Schedule B, which are not necessarily cover everything passed 30K-40K miles.
Intervals that Make the Mercedes-Benz GLB Service Schedule
There are two service intervals to pay attention to. The first of the Mercedes-Benz GLB maintenance schedule is Service A and the second is Service B. Service A* is performed at 10,000 miles or 1 year, whichever comes first. The second service interval, Service B*, is performed at 2 years or 20,000 miles, whichever comes first. After these first milestones you’ll continue to alternate between Service A and Service B.
What are Mercedes-Benz Service A Tasks?
  • Synthetic Motor Oil Replacement**
  • Oil Filter Replacement**
  • All fluid level checks and corrections are dependent on factory-recommended service intervals for your vehicle’s year and model
  • Tire inflation check and correction
  • Brake component inspection
  • Reset maintenance counter
  • Adhere to all required elements listed by model year and specific model as indicated on the corresponding service sheet for Mercedes-Benz Maintenance Systems in the USA.
What are Mercedes-Benz Service B Tasks?
  • Cabin dust/combination filter replacement
  • Brake fluid exchange
Old Jan 10, 2023 | 08:06 AM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
https://www.waltersmercedesbenzofriv...ice-intervals/
Synthetic motor oil replacement
Every 10,000 miles / 1 year
Cabin dust/combination filter replacement Every 20,000 miles / 2 years
Brake fluid exchange Every 20,000 miles / 2 years
Wiper blades set Every 10,000 miles / 1 year
Spark plugs replacement Every 50,000 miles
Engine air filter replacement Every 50,000 miles
Transmission oil & filter replacementEvery 60,000 miles (MY 2015 or newer only)
On GLK 350 (similar to ML350), the battery / belts were replaced at 7 years ~ 65-70K miles under regular maintenance. Auxiliary battery lasted 8 years.
Old Jan 10, 2023 | 11:41 AM
SRNH's Avatar
Good Morning Vlad, I tried to upload a simple 5 page PDF and can't get it to upload or else you'd see what I mean, MB use to provide a detailed listing to the dealers of which I obtained. I'll try to PM (if I can) it to you and perhaps you can post, issue probably on my end......... I agree with your assessment, incomplete data out there...... The items I want to see ahead of me are things like the Fuel Filter, the Poly Bely, etc. MB use to have a firm elapsed time or mileage when certain components needed to be changed regardless.
Old Jan 10, 2023 | 11:50 AM
I got email notification from MBWorld but no attachment was included with the message.
Old Jan 12, 2023 | 01:30 PM
SRNH's Avatar
ATTACHED EXAMPLE DEALER SERVICE SHEET
Finally, the upload of the example ML350, had to change it to a PNG File. again, this is what I'm looking for with the GLB............
Old Sep 20, 2023 | 10:14 AM
MBLoverSC's Avatar
GLK 350
I have 2015 GLK 350 -- I had the Service B done over a month ago, but cannot get the notice to stop showing when I start the car.
