Check 48volt Battery Charge Level?
Turn ignition to position 1
Wait for all displays to complete
Press HOME and go to "Classical" display (others may work)
Scroll until the center screen displays vehicle miles (km) and trip miles (km)
Press and hold the HOME button for 10 seconds, then release
Press and hold OK for 10 seconds, then release
Press once the HOME button
"Workshop" display should be an option
Press OK to select "Workshop"
The "Workshop" menu should appear in the center windo
Scroll if necessary to "Vehicle Data"
Press OK to select
12 volt battery status should be shown
scroll down to see 48 volt battery status
With the ignition still in position 1, voltage and current will show "0"
Turn ignition to position 2 and start the engine. % charge will be shown
To exit press HOME and select the desired display...
As with my previous experience with MB's 48 volt system (CLS53 & GLE53), charging the 12 volt battery with a charger connected to the charging terminals in the engine compartment does NOT add charge to the 48 volt battery. It is only charged when the engine is running, including idling.
Press OK to select
