Screeching Brakes on the GLC
Old Apr 5, 2019 | 10:58 AM
  #551
VancityGLC's Avatar
2019 GLC 300 4-Matic
So after replacing the front pads by the dealer under warranty, everything was good for about a week and then the screeching sound came back but I could easily point the sound to the rear brakes. Will take it back to the dealer to change the rear pads as well.
Old Aug 14, 2019 | 04:43 PM
  #552
ecdubreuil's Avatar
2017 GLC300 Coupe 4matic
Squealing brakes
When mine first started doing this, it was only on very cold winter mornings. Dealer said "It is normal, nothing we can do." Now with about 24k miles on it, it happens every day. Even when it is 80°F in the garage. (Wicked loud, you can hear it for blocks.) I am going to video it tomorrow before I take it to the dealer for scheduled maintenance. Sure I will get the same run around, but he will recommend I get some $80 wiper blades.
The best or nothing...
Old Oct 24, 2019 | 08:38 AM
  #553
George Bennett's Avatar
2017 GLC 300
My situation is identical. 23,000 miles and a squeal every morning now. I contacted my original dealer who wrote this to me. "...two attempts to repair the front brake noise have been made, one on 5/18/17 and a second on 12/04/18. However these were both before the introduction of the noise optimized brake pads. The original old style 8100 pads were used in both repair attempts."
I am going in for another attempt. Hoping this info might help people.
Old Oct 24, 2019 | 10:14 AM
  #554
ecdubreuil's Avatar
My dealer won't even look at it. It is normal...It will be my last Mercedes.
Old Oct 24, 2019 | 12:05 PM
  #555
2020GLC300's Avatar
2020 GLC 300
It's all in the pads. If Mercedes is putting on squeaky pads, then it is in fact normal. The dealer can put on new Mercedes OEM squeaky pads, and they will squeak again.
In Europe, apparently the masses there don't care about squeaky brakes or crazy brake dust, but here, we are annoyed by it. I know I am. My 2020 GLC300 seems to have quiet and dust free pads so far, but if they start causing problems, I don't have an issue to drop in new pads instead of whining about it. Akebono is my number one choice, so if they make them for a car I own, I always go with that pad. Centric Quiet Stop and Powerstop make decent ceramic pads that don't dust or squeal, so they are my backup choices.
Old Oct 24, 2019 | 01:19 PM
  #556
gqboy's Avatar
GLC 300
What's the highest mileage someone has brought their car in to have looked at for this issue? My GLC has 74K km and it's squealing every morning when I reverse. Wondering if they'll tell me I'm outside warranty and sol.....
Old Oct 26, 2019 | 11:25 AM
  #557
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
d
At your mileage, unlikely you'll get it fixed at no cost. On the other hand, noisy brakes have been problematic since nearly day one so if your persistent, the dealer may relent.
Old Oct 26, 2019 | 07:40 PM
  #558
Mr. J's Avatar
C450, GLC43
Have you had the pads replaced yet? I know the 300s wear slower but my '43 needed brakes at 25k.
Old Oct 26, 2019 | 07:43 PM
  #559
Mr. J's Avatar
C450, GLC43
EBC yellowstuff are performing well on my C450. They bite well even when cold. They are a little dusty but much better than OEM. I'm not sure if they make pads for the GLC.
Old Oct 27, 2019 | 02:38 AM
  #560
Mr. J's Avatar
C450, GLC43
Looks like they do. My mechanic told me that the Green stuff were squeaky on a BMW instal he did. Yellows have been great on my C450 so far.
https://ebcbrakesdirect.com/automotive/mercedes-benz
Old Jun 5, 2020 | 08:57 AM
  #561
GKH's Avatar
GKH
GLC300(C253)
Clip missing due to design
I have GLC300(C253) produced 09.2018.
The problem with brake squeal started after 1 year, approx 9000 km.
By my opinion the noise is coming from rear brakes. I have following explanation:
99 % of the time/distace the car is run in fwd direction. Thus the brake pads are "beding" in specific way /angle against rotors.When drive reverse the "beding" interferes with rotors in different way-in very narrow edge like area. The vibration of pads start in the way of contact between caliper and pad ends. The squeal is coming from friction between pad, caliper and dust present around from pad material.
Why the noise is coming after a time from delivery of the car-due to accumulation of dust from pad material, which covers the entire system.
But the strangest thing of all of this is
WHY MBZ DID NOT INSTAL THE STAINLESS STEEL CLIP, which many other brands do and there are no any similar problems.
The idea the end part of the pad to contact with cast iron caliper is strange and most probably is the main reason for noise issue. It looks as poor engineering. The rubber shim on the back of the pad is only available as preventive measure.
In order to prove above the copper grease and spray oil was applied in area of contact and noise disappeared for a while.
Down below are puctures of:
1.GLC rear brakes where pad ends are clearly shown in area of contact with cast iron caliper.
2. Toyota corolla rear brakes with clips.
3. Brake clip.
4. Other brand(Lexus RX brake system)
Clip
Old Mar 10, 2021 | 01:29 PM
  #562
captpablo's Avatar
2016 GLC300
2016 glc and have had this problem for years with no help from service department. Am now attempting my own brake job. If anyone has info on e torx size for brakes, I would appreciate it.
Old Sep 18, 2025 | 11:15 AM
  #563
GKH's Avatar
GKH
GLC300(C253)
Update on subject issue
Hi.
W213 rear caliper
W213 rear caliper
W213 brake pads
W213 brake pads
During replacement of all brake pads,it was noted, that there were multiple areas seen on pictures,
where brake pads directly contact in brake caliper. In GLC(X253) there is NO stainless steel anti
rattling plates. If You take a look at design of brake pads for W213(E class) it will be noted, that
there are specific stainless steel plates, preventing or reducing friction.
Sorry to say, but for me it is 100% clear, that MB just saved few dollars and ruined the image
of the brand, because noise is coming from design flaw.
I applied copper grease in contact areas and there is NO noise in both cases-forward and reverse,
but this is a temporary solution. To apply grease to inner contact area is relatively hard.
I accepted that, it is NOT possible to solve this problem.
Old Jan 17, 2026 | 05:53 PM
  #564
MBNUT1's Avatar
2010 E350 4Matic
Hello GLC owners. Had dinner with friends of mine that have this model GLC (2021) and they brought up the brake screeching issue. They said that the dealer said that is inherent in the design and there is no fix. Based on the last post it seems like the dealers claim is valid. Is that the message that I should pass on to my friends.
Old Jan 20, 2026 | 12:39 AM
  #565
waylo's Avatar
2018 GLC 300 4MATIC
Reports first came out in 2016. We had it with our GLC then. We brought it in, and the dealer I believe replaced the brake pads, and the noise stopped. Though that did not happen for everyone.
We traded in for a 2018 GLC 2 years later. That one did not have the issue ever.
I would have your friends ride the dealer hard to at least swap out brake pads, to see if that makes any difference. Did they purchase it new? Has it been going on the whole time they've owned it?
Old Jan 20, 2026 | 07:47 PM
  #566
MBNUT1's Avatar
2010 E350 4Matic
Thanks for the reply. Pretty sure they bought it used from the same Mercedes dealership. As best I can tell it has been an issue since their first cold days with the car.
Old Jan 20, 2026 | 10:49 PM
  #567
waylo's Avatar
2018 GLC 300 4MATIC
Yes, cold AMs was when the sound would really go crazy. Early Youtube videos from that time showed some owners waking up the whole neighborhood with that terrible noise.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
