GLC Failed to proceed.
"Not Happy Jan".... I would have thought you could limp home with these faults. Surely an over ride code, even if it meant any passenger got in the rear seats to minimise issues.
I understand versions of the G Wagen have the ability to have issues like this switched off, or at least overwritten. Maybe we all need a cheap Bosch OB11 ? Computer reader, reset tool in our glove box for minor issues and practical safety over rides ?
Lift Bonnet
Remove Battery Cover
Disconnect Negative Terminal (Never use spanner on positive terminal)
Wait two minutes
Reconnect Negative terminal
Car will hopefully start.
Replace battery cover
Close bonnet
Drive directly to dealership.
Main problem with this method is that you clear the fault codes making dealer diagnosis more difficult but at least you can drive the car to the dealer, the alternative is a tow truck and then all the fault codes can be read by the dealer.
