Want to install rear seats screens, need help which fuses to tap into
I have a rear seat entertainment center LCD screens that I need to connect to the fuse box and it comes with these 3 connectors:
https://s11.postimg.org/5f5a0i6ab/IMG_3588.jpg
I am thinking of just using couple of these for the red and yellow wires :
NEW Double Mini Blade Fuse Socket Wire Tap SF5125 | eBay
but need to work out which fuse to connect to. I assume ACC+ can go to the cigarette lighter socket fuse and the yellow can go to any that has 12V power. Ground is easy.
any thoughts?
can someone post a photo of the fuse box diagram ? Which fuse box do I use for these?
Also, I will also be installing a dashcam which will tap into one of these, probably also the cigarette lighter socket fuse.
any thoughts?
