GLC exterior lighted door handles
Are the lighted exterior door handles a standard feature? If, not, what package or option is it included? Can it be enabled or disabled in COMAND?
I am not sure about the light in the door handles as I would believe it's standard feature. You should check your command system because you can enable/disable it. The chrome strip on the handle is for comfort/keyless entry. If you don't have that option then it will be normal body colour.
Current: 2022 C300W4, 2016 Audi A8L Previous: 2019 C43W4
Did you order your vehicle with Keyless Go?
Nope. We did not order keyless go. We thought the lights were standard.
Can the lights be retrofitted? I imagine one must take off the door panel to do so.
Chances are very good there's a whole host of wiring that the lit doorhandles would require--not to mention supporting software, etc. Don't bother.
