2018 GLC43: consensus on spacers and lowering
Hi guys,
I just got my wife a 2018 GLC43. I've been digging around here and more broadly on the Internet but I'm not arriving at a strong consensus of 1) what size spacers to use with the factory 21" AMG 5-spoke wheels and 2) whose lowering module to go with. For #1, I'm thinking 18mm (perhaps even 20mm) front and 12mm rear. I've used a lowering module from Ebay on my 18 E63S but haven't yet confirmed if either it'll work or if they have a model compatible with the GLC (assuming compatibility is even a question).
Does anyone have any pics of the sort of setup I'm looking for and the products they used?
These are the H&R part numbers for the spacers posted in another thread but sadly no pics and the larger spacer was used on the rear which this car doesn't need (to my eye, at least):
3055665SW - 15MM
4055665SW - 20MM
Thanks in advance for any input!
3055665SW - 15MM
4055665SW - 20MM
Search username TOOGECKO in this category (GLC43). I did a lot of research and even rented a spacer sizing kit to determine best width when I bought my car. I also believe spacer part numbers and bolt lengths were listed.
Hi guys,
3055665SW - 15MM
4055665SW - 20MM
3055665SW - 15MM
4055665SW - 20MM
Thanks. I found the thread.
So the spacers don't come with extended lug nuts, that's unusual. When I buy spacers for BMWs, they come with appropriately-sized lugs nuts. Did you find a supplier that was able to deliver them with a reasonable turnaround time? If so, who was that?
Yeah, I've dealt a fair bit with ECS, too--they've always been great. I think I got a number of mods for my RS7 from them. This time, though, I couldn't find the spacers searching with car model etc., I suspect your part numbers will help.
Looking at my wife's GLC (it's the 43) coupe, the front tires appear far more inset/subdued than the rear's and yet in your setup, you went with 20 rear, 15 front. That leads me to wonder if perhaps if either 1) I'm blind [quite possible] or 2) the wheel setup between our two models is different. Any thoughts (other than yes, I'm blind)?
Thanks again.
I did--looks great! Hence my question wrt/ the wheels/offset/differences between the Coupe and non-Coupe. Were your fronts noticeably more inset than the rears when stock?
in the front due to that appearance. But ultimately, I wanted to maintain the same factory stagger ratio and I did not want my wheels sticking out past top of fender. Remember, it is much easier to curb a fro t wheel than back (so I’m told!).
The Following User Says Thank You to TOOGECKO For This Useful Post:
limeypride (01-20-2019)
