Technical difference between GLC 63 and 63s
Old Jul 28, 2019 | 06:05 PM
ogie1's Avatar
porsche macan
Hi guys.
I’ve search online but can’t really find all the details.
I think this a 2 part question. What makes the hp difference between. 63 and 63s. Is it just tune or parts as well? Are there other technical difference between 63 and 63s.
Thank you
Old Jul 29, 2019 | 02:50 PM
Chrisk03's Avatar
GLC43, GTI, X3, Mazda3
Originally Posted by ogie1
Hi guys.
Thank you
I'm trying to find the info, but I believe it's just tuning. No difference in actual parts from what I recall.
Old Jul 29, 2019 | 03:21 PM
mrmotoguzzi00's Avatar
found some info here......
https://www.caranddriver.com/reviews...s-coupe-drive/
Old Jul 29, 2019 | 03:41 PM
Chrisk03's Avatar
And here's the article I remember for the present model, but nothing in 2020 will change engine-wise. 4th paragraph mentions software only changes...
https://www.caranddriver.com/reviews...y-the-numbers/
Old Jul 29, 2019 | 03:58 PM
ogie1's Avatar
porsche macan
https://mbworld.org/forums/glc43-glc...lc-63-63s.html
you quoted this thread
Old Jul 29, 2019 | 04:12 PM
Chrisk03's Avatar
Fixed, thanks! Ctrl C / Ctrl V doesn't always work...
Old Jul 29, 2019 | 04:34 PM
JasonB001's Avatar
GLC63S
Rear diff's different between the Non-S & the S. They both use the S E-differential from 2020 moving forward.
Old Jul 29, 2019 | 09:54 PM
Henry Stark's Avatar
GLC63S
S has more horsepower, active engine mounts, electronic diff, wheel options, and expensive badge that says S and bragging rights.
Old Jul 29, 2019 | 10:27 PM
CPD SLK's Avatar
2009 C63 AMG
I didn't know they had different diffs... especially since even non S models require the 1800 diff fluid change. So non s models have mechanical limited slip diffs?
