2019 Glc 63 AMG (x253) oil leak issue
Old Oct 11, 2023 | 12:29 PM
fflow's Avatar
2019 GLC 63 AMG 4matic+
I bought a used 2019 GlC 63 AMG (28000 mi), I have found some oil leak spots as the pictures below but I am not sure where it comes from or when it happened.
Some yellowish spots look old, and other wet (Black) spots seem the oil leak is ongoing.
Is there anyone has the similar issues or anyone know this is common issue on X253(I guess M177) ?
If I can try to replace a part (like oil pan, gaskets or something) at first, Please recommend.
Should I take apart the engine assembly for further inspection?
​​​​​Since I am not an expert on mechanics, any one can address this issues and the part location with part name based on the picture below would be great.
My GLC is in South Korea now.
Old Oct 11, 2023 | 12:47 PM
superswiss's Avatar
2019 C63CS
I could be wrong, but if I'm looking at your pictures correctly, then it looks like your front differential is leaking. The 4Matic+ front differential leaking is not unheard of. There's a clutch in there operating under hydraulic pressure, so if any of the seals have dried out for example or if the diff got damaged driving over something then a leak is possible. I personally don't have experience with it or know how common it is as my AMG is RWD.
Old Oct 11, 2023 | 01:08 PM
fflow's Avatar
THANK YOU
Thank you for the info. I guess you are referring to the yellowish spot on the diff in the second picture (I May be wrong).
How about the rusty screw spot (seems massive leakage happened) in the last picture? The spot is located on the other side from the diff.
and is the Black plastic box oil pan?
Is this correct?
Old Oct 11, 2023 | 03:17 PM
OmegaM177's Avatar
glc63
I'll second the possibility of it being the front differential. My 2020 with 20k miles was leaking in the pre purchase inspection and I was able to have them fix it before I bought it.
Old Oct 11, 2023 | 03:30 PM
superswiss's Avatar
2019 C63CS
Is this correct?
That's all part of the differential I think. I believe the black box is the electronics for the 4Matic system. The mechanics and electronics for that are all part of the front differential. It uses a multi-plate clutch to variably couple the front axle to the transmission shaft. It could also be the transmission control unit/valve body, but kinda hard to tell with these close up pics. Do you have one zoomed out further?
Old Oct 11, 2023 | 08:17 PM
fflow's Avatar
Unfortunatly, I couldnt take on zoomed out further, but it looks control unit because I can see the cable and the harness plug-in. THANK you for help.
Old Oct 11, 2023 | 08:20 PM
fflow's Avatar
THANK you for the note.
Old Oct 14, 2023 | 05:00 PM
chassis's Avatar
2017 GLE350 4MATIC
Wipe the wet fluid with your finger and smell it. Engine oil and axle (diff) fluid have distinctive aromas.
How long have you owned this car? Was the underside bottomed or impacted?
Old Oct 20, 2023 | 04:07 AM
fflow's Avatar
Zoomed out one
Here is the zoomed out picture.
Old Oct 20, 2023 | 04:11 AM
fflow's Avatar
Zoomed out one
I am not if this is really about differential part.
Old Oct 20, 2023 | 04:45 AM
chassis's Avatar
2017 GLE350 4MATIC
These pictures are really bad.
Please draw a red circle on the photo at the location of the leak.
Do you know what cosmoline is? Do you have cosmoline in the photos?
Old Nov 13, 2023 | 12:27 PM
W205C43PFL's Avatar
Ya... need a better picture OP for us to better diagnose the issue.
Old May 2, 2025 | 08:22 AM
Evan63's Avatar
Did you find out what caused the leak? My e63 is looking exactly like this.
Old May 3, 2025 | 11:34 AM
W205C43PFL's Avatar
OP didn't give us a better picture and didn't comment again. Show yours and see if we can help.
