View Poll Results: Has anyone had this same type of problem?
Yes
12.50%
No
87.50%
Voters: 32. You may not vote on this poll
48-volt battery
Old Dec 21, 2020 | 05:31 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Originally Posted by toban
Now, I’m new at this like everyone else but I did talk to the head mechanic at the dealership and he confirmed when the car is running, the generator charges the 48V battery and the 12V AGM battery together. He said if you put a battery charger on the charging posts it will place a charge on the AGM through the converter and charge the 48v lithium lion battery too. I’m now trying to find out if a special charger is needed.
I hope this is right because It would be very disappointing to be spending this much on a problematic system.
I hope MB gets it right in January as this is when my car goes into production.
thanks for you comments and anything else people find out would be appreciated.
Toban
As I recall this has been discussed before and a special charger was necessary. Seemed like it was more than just AGM compatible. But....if the 48 volt has an internal short or whatever keeps it from holding a charge then it might not be possible to charge it anyway. I did a search and couldn’t find the discussion that might have been about a year ago.
Old Dec 21, 2020 | 05:47 PM
mikapen's Avatar
Toban
Correct. The way the 48v system charges the 12 battery is through the 48-12v converter.
And the way the 12 system charges the 48v battery is through a separate 48-12V converter.
A special charger, or battery manager, would not be needed - you are just trying to get enough charge into the 48v battery to start the car. The onboard converter will see to that.
Old Dec 21, 2020 | 05:55 PM
mikapen's Avatar
Originally Posted by Brer Rabbit
I believe (page 584 of the owner's manual) that the AGM battery charges the 48-volt lithium battery via the voltage converter. The charger you buy should be AGM battery compatible. CTEK makes them.
CTEK is the brand M-B sells, rebadged as M-B. Battery Tender is another brand, that also has 4 stage charging. They both have 4 stage charging, and they both will maintain AGM batteries.
But AGM compatibility is not necessary if all you are trying to do is get enough charge THROUGH the 12v battery, INTO the 48v battery to start the car. Any charger/maintainer should do the job, as long as you don't ask it to fully charge and maintain both batteries. I doubt that it would be possible with the M-B converter in the path.
Old Dec 21, 2020 | 06:00 PM
whoover's Avatar
'19 E63S sedan
This is the CTEK charger that I use. It's newer technology than the one M-B brands and is cheaper. CTEK is the state of the art in AGM chargers. Again, you just need a good AGM charger as the 48V lithium battery is charged indirectly.
Amazon Amazon
Old Dec 21, 2020 | 06:03 PM
mikapen's Avatar
Originally Posted by whoover
The starter is 48V so if there is a problem with the 48V circuit the car can't start. If the 48V battery fails it won't take a charge so you're dead in the water. The concept of using another vehicle's (12V) battery to power the starter is not applicable, so jump-starting doesn't compute. And there's no provision for 48V-to-48V jump starting because, even if AAA had 48V available, it would be way too dangerous to both people and onboard electronics.
Correct, there would not be a clear-cut way to jump start directly form a 48v battery to the onboard 48v battery.
But you can get enough charge by connecting a 12v battery to the GLE 12v battery posts, and allowing the GLE converter to bring up the 48v charge.
It may take some time, but jumping a dead 12v battery in a 12v car always takes quite a bit of time, while the dead battery gets enough charge to spin the starter - same situation with a dead 48v battery. Follow the normal jump start procedures, connect the negative lead to a ground point distant from the battery itself, and keep the charging car running.
M-B has already planned for these situations, by providing the 12v jump start connectors under the hood, and separating the ground point from the battery.
Old Dec 21, 2020 | 06:04 PM
Brer Rabbit's Avatar
Veteran: Air Force
'20 GLE 450, Silverado 3500
Yes, CTEK makes the MB charger. Back in Oct I emailed CTEK and got the following email when I asked about a charger for the GLE 450:Hello,
There are many charger options for you including the Mercedes-Benz branded charger that is manufactured by CTEK. This charger is available through your local Mercedes dealership.
If you are interested in a CTEK branded charger, our MXS 5.0 (40-206) is designed for lead-acid and AGM batteries up to 160Ah. If your vehicle battery meets this criteria the MXS 5.0 will also work well.
For more information on our MXS 5.0, please click on the link below:
https://smartercharger.com/collectio...s/ctek-mxs-5-0
Thank you,
I figured if I was going to buy a charger, I would get one that was AGM compatible.
Old Dec 21, 2020 | 06:06 PM
  #32
mikapen's Avatar
An internal short in the 48v battery would kill the whole idea. And the car would be un-startable.
Same with a shorted 12 v battery.
There was this discussion in the 60's when cars went from 6v to 12v, and we all survived.
Now, there is more demand on auto electrics, and 48v is needed to drive everything.
Old Dec 21, 2020 | 06:16 PM
  #33
mikapen's Avatar
Thank you,
There are many battery chargers/maintainers out there, and the reputable ones all charge AGM's and others.https://bestfordriver.com/chargers/b...harger-review/
Lithium chargers are the next step, and now there are several choices. https://www.batteryfocus.com/lithium...harger-review/
(I just did a quick search for those links - I don't endorse any of them, but I have a slew of Battery Tenders for several styles of batteries I have.)
But I doubt that any of the algorithms in any of those would "see through" to the 48v volt battery, if that's the goal.
Old Dec 21, 2020 | 06:20 PM
  #34
whoover's Avatar
'19 E63S sedan
Yes, if the 48V is merely discharged. But if the battery is bad, it won't take a charge, which is what has been happening. If a 12V battery is bad, a jump start will get you to a shop and a new battery. If a 48V battery is bad, you need a tow.
Old Dec 21, 2020 | 06:23 PM
  #35
Veteran: Air Force
Gees!!! Not the goal at all. Where did you get that idea? I am talking about buying a charger for the 12V AGM battery. That will take care of the 48volt battery all else being fine.
Old Dec 21, 2020 | 06:45 PM
  #36
MikeFLA's Avatar
2020 GLE450
Originally Posted by Lucky 777
So if this battery fails, the car is a dead stick? I'm amazed MB doesn't have software in place to allow the car to still operate with the inline 6 alone.
Problem is the water pump runs on the 48 volt system, so when that fails, the car overheats quickly.
Old Dec 21, 2020 | 06:54 PM
  #37
MikeFLA's Avatar
2020 GLE450
It’s just a bad batch of batteries & not an ongoing problem. This is just a very recent issue, the 48 V has been solid for the prior 18 months. I recently sold my GLE 450 after ordering a GLE 53 and completely agree with Mikapen. The fuel economy and silky smooth drive train/engine make it the best in class. If it wasn’t for the gauge showing the EQ Boost in action, you wouldn’t know it’s even there. You won’t regret buying a 450....
We have one individual continually running the Mercedes GLE down posting the same crap. His dealer wouldn’t repair an oil leak (on an older car) to his satisfaction so now he jumps at the chance to cheerlead against the brand. IMO, ignore his posts and look for facts.
Edit: There is a Mercedes me notice when the 12 volt gets low on charge but I don’t know if it’s also going to work on the 48V Lithium. Other Lithium batteries I’ve used in tools just die when discharged vs NMH that get too weak to function but still have a little power.
I hope it's a recent issue. My GLE450 is a March 2020 build and the 48 volt battery failed after 9 months.
  #38
mikapen's Avatar
I thought this was a thread about getting a dead 48v GLE started. I guess I shouldn't have quoted you, because I misinterpreted your goal. Apologies.
You are correct, though - placing any of the low-amp charger/maintainers and keeping the 12v battery fully charged for a longer period, SHOULD bring a healthy 48v battery back to starting capabilities. Days or hours? Does anybody know the Amp-Hr rating of the 48v battery?
I'd try a jump start first, where you get the full output of a charged battery pushing electrons to the 48v system, with the onboard GLE battery as a buffer. And wait for a while for the amps to build up.
Old Dec 22, 2020 | 09:00 AM
  #39
MarkerVB's Avatar
2021 GLE 450
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thank you,
Thank you both for these links. I'm getting (supposedly soon) a 2021 450 and will leave it garaged and unused five month of the year. I will use the CTEK trickle charger even though it appears I might be able to get away with a cheaper one.
Old Dec 22, 2020 | 11:31 AM
  #40
toban's Avatar
2021 GLE 450
Okay, we’re getting all kinds of different signals how you can charge this 48v battery. Many people are saying you can charge the battery through the converter from the posts under the hood through the converter. Others have said the converter only works one way from 48v to 12v and not the other way around.
so, this last poster is going to let the vehicle sit for 5 months with a battery charger hooked up to the posts and the thought wax it will keep the 48V battery charged also through the converter?
so, who’s right here I wonder? I wish MB would come out with an answer or explanation?
I’m really confused now what will work and not work.
Toban
Old Dec 22, 2020 | 12:23 PM
  #41
jtjbt20x's Avatar
2021 GLE450W4 SUV
According to pages 430-431 of the 2021 GLE operating manual, the 48V battery is charged by the 12V circuit. You can see this in the attachment below, but this is the applicable part:
"Connect a suitable charger approved for Mercedes-Benz with sufficient charge output to the jump-start connecttion point of the 12 V battery. The 48 V battery is charged via the voltage converter in the vehicle."
File Type: pdf
Old Dec 22, 2020 | 12:45 PM
  #42
whoover's Avatar
'19 E63S sedan
Toban
There are two DC-to-DC voltage converters in the car. The "alternator" is 48V (one of the ISG functions) and charges the 48V battery directly as well as the 12V battery through a 48-to-12V converter. There is also a 12-to-48V converter that charges the 48V battery from the 12V system when it has more charge, as when the car is sitting with a 12V charger connected.
Old Dec 22, 2020 | 01:30 PM
  #43
quattrogmbh's Avatar
various
The VW Group, BMW and FCA (including RAM trucks) all use 48v, some optional - but they are belt-driven. 48v is the future of ancillary power systems.
There is a Standard that 60V or above needs additional safety features, and 48V systems can charge at up to 52V, so the 48V batteries are the sweet spot for cost-effectiveness.
Right now, M-B is the only manufacturer using the inline starter-generator. It's the simplest and most efficient of the current (!) systems. And, as I understand, the 4:1 and 1:4 voltage conversion emit less electrical Noise that other voltages, needing less shielding.
Expect a widespread adoption of 48v systems in the near future, as fuel economy and clean air regs get tighter.
And the fuel savings are real. I have spent a month in a GLE450, two weeks in a GLE350, and own a GLC300 - the last two have the 2.0L four. Guess what - in normal driving, I get essentially the same mpg in all the above, perhaps a bit more with the GLE450. That's saying a lot, especially because I am somewhat tempted to enjoy the smooth acceleration of the straight six. I.e. bury my foot more, in the 450.
The added EQ Boost is real, and regenerative braking is smooth, probably saving brakes, and the elimination of drive belts free up significant power to the wheels.
I know that M-B had a setback, when Tesla bought M-B's main battery supplier and violated the development/supply contract that they had. The CEO of that company (can't remember its name right now) was fired when he wanted to honor the legal contract. This made me realize just how ruthless E. Musk is, and probably just how ruthless the future of electric cars and autonomous driving will become.
do you have this documented somewhere or is it just opinion?
Old Dec 22, 2020 | 01:53 PM
  #44
mikapen's Avatar
See post #22 in this thread. Several links in the referenced article that expand the story.
Old Dec 23, 2020 | 10:27 AM
  #45
user 7208224's Avatar
2020 GLE 350
One of the biggest drivers for a move to 48 volt systems is the weight savings. As the ever increasing amount of electrified technology went into vehicles the load on 12 volt systems grew exponentially, requiring more, and larger conductor size, copper wire. Moving to 48 volts reduces the amount of wire and the conductor size making those wiring harnesses smaller and easier to design and install. The reduced current also results in reduced heat.
Old Dec 23, 2020 | 11:38 AM
  #46
MikeFLA's Avatar
2020 GLE450
I understand all the reasons for the 48 volt supply. It just needs to work, which as of now there seems to be real problems with either bad batteries or software, or? If the car didn't shut down in the middle of the road when the 48 volt system was in trouble, that would be an improvement. I read where the Audi new Q7 uses a 48 volt system, BUT, the critical car functions are still driven by a belt. This would most likely prevent the car from overheating immediately since one would think it is still driven by the belt and is not electric.
Old Dec 23, 2020 | 12:45 PM
  #47
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
48v system
While it is true wiring weight is saved, I seriously doubt it offsets the weight of the extra battery. Of course there are many other advantages which have been cited - elimination of belts, a seamless start/stop system, ability to run accessories like AC while engine is off, fuel economy, etc.
Old Dec 23, 2020 | 01:17 PM
  #48
MikeFLA's Avatar
2020 GLE450
I agree with the idea of a 48 volt system, no belts, efficiency, etc. However having been, well still going thru this 48 volt failure ordeal, I'm wondering about the reliability issue. The fact that this particular failure can render the car useless at anytime, anyplace, within seconds, which it have proven to be true, I would chose a belt if I could keep the car running at this point. If the AC goes out, or the hybrid system doesn't work, you could still drive the car to the repair shop. I'm thinking that Audi, and others who still employ a belt along with the implementation of a 48 volt system might have thought this out a little more thoroughly. My opinion.
Old Dec 23, 2020 | 01:51 PM
  #49
whoover's Avatar
'19 E63S sedan
It still seems that the biggest issue with all of these 48V systems is the starter. If the 48V circuit fails for any reason, including a battery defect, you can't start the car. Having a belt-driven water pump won't help. It's only of use in the rare circumstance that the car is running when the battery dies. Yes, you might be able to drive it to a shop. But with no way to jump-start a 48V starter (which all these systems use), you're not going anywhere. It would seem a safe and standard way to jump-start a 48V car is the missing technological piece.
Old Dec 23, 2020 | 02:01 PM
  #50
jtjbt20x's Avatar
2021 GLE450W4 SUV
See post #41 above, it appears that you can jump start a 48V system as long as the battery isn't dead/defective according to the operating manual.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
