Driver-side reading light behind rearview mirror keeps turning on
Old May 18, 2021 | 07:07 PM
Steve Armstrong's Avatar
2020 GLE350
Lightbulb Driver-side reading light behind rearview mirror keeps turning on
2020 GLE350 with 900 miles - While heading home from dinner the other night, the driver-side reading/map light kept turning on. It would only turn off if I pressed the driver-side light switch.
I wasn't doing any "gestures" if that matters. Is there a setting I should check?
TIA
Old Sep 2, 2021 | 02:29 PM
Ezaz's Avatar
2020 GLE 450
Same problem here
TIA
This problem very few people would know about. Because this gesture option is limited on GLE.
I have gone through your problem but on Passenger side. Reading light automatically kept turning on, when I turned it off by pressing switch, it would go off but again kept turning on automatically.
I took the car to the dealer then they were also shocked to see (As this model and option is very new and technicans have less to no knowledge regarding fixing). Then they permanently closed this option. Now the gesture does not work.
Old Sep 2, 2021 | 07:10 PM
2020 GLE350
Well that sux.
Did the MB Techs actually reprogram something using a tool or computer? Or was it using the GLE's MBUX system settings?
Old Sep 2, 2021 | 07:22 PM
SmokinJoe's Avatar
2021 E-350 Loaded
Any chance the overhead camera behind/near the rear view mirror is dirty?
I failed to order the in-car assistant and wished there was a way to get it.
Old Sep 2, 2021 | 07:43 PM
2020 GLE350
Doubtful on my end. The car is immaculate but it doesn't hurt to check and clean, I guess...
Old Sep 2, 2021 | 09:31 PM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
This happened to me once. The right rear inside light and the driver's side reading light came on randomly while driving. Stop / open door / close door / restart engine about 5 times and it went away and never came back.
Old Sep 3, 2021 | 05:47 AM
Ezaz's Avatar
2020 GLE 450
[QUOTE=Steve Armstrong;8409250]Well that sux.
Did the MB Techs actually reprogram something using a tool or computer? Or was it using the GLE's MBUX system settings?[QUOTE]
MB Tech reprogrammed through diagnosis computer as it is never possible through MBUX.
Old Sep 3, 2021 | 05:49 AM
Ezaz's Avatar
2020 GLE 450
Well that sux.
Old Sep 3, 2021 | 05:53 AM
Ezaz's Avatar
2020 GLE 450
Will happen again
I have done the same procedures like you. Stop/Open/Close/Restarting several times. It went away temporarily. But after few months again came back. It is like a Cancer, never goes away.
Caused me much trouble to drive at night. So, I made the decision to turn it off permanently through dealer. 😔
Old Sep 3, 2021 | 05:54 AM
Ezaz's Avatar
2020 GLE 450
The car is very clean in and out. Started causing the trouble from a month after the brand new purchase.
Old Sep 3, 2021 | 08:28 AM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Sounds like a camera or camera calibration issue to me. I’d make the dealer fix it, disabling it is not fixing it, you paid for that option. Did you try taking it to another dealer?
Old Sep 3, 2021 | 09:26 AM
Ezaz's Avatar
2020 GLE 450
You are absolutely right. But as I live in Bangladesh, here only one dealer is available and they don’t get such problems often. Also, GLE V167 was very new in this part of the world when I tried to fix the issue.
Moreover, as this problem occurred once in a blue moon, so I could not show it to the dealer. Rather made them understand about the fact.
The light caused much distraction at night, specially on freeways. So, all I did was turning off the function. Very saddening indeed.
Old Sep 4, 2021 | 03:53 PM
TwinCam's Avatar
2021 Cirrus Silver S580 AMG, 2020 Polar White GLE350
Try this, go to “settings”, then “quick access”, then to activate/deactivate “interior motion sensor”. Hit Deactivate. Then turn off car, get out and lock it. Then unlock the car and restart. This may reset the system. If that does not work, try deactivating over night and then reactivate the next day. I don’t know if this will work, but it is worth a try. Instructions on the interior motion sensor are on page 96 of the US manual.
