Frustrated with GLE, thinking about selling. Thoughts?
Old Jul 31, 2021 | 10:02 AM
Imanone's Avatar
2022 GLE 450, 2024 Volvo XC 60
Old Aug 1, 2021 | 07:38 PM
digital_b's Avatar
2026 E450
probably a customer buy back vehicle. running the vin will show this and its known issues. 167 point inspection my ***. you bought what you thought was a cheap benz. and now you know why.
Old Aug 2, 2021 | 09:49 PM
CMFUSA's Avatar
GLE350 (2021), 991.2 (2019)
Not a customer buy back, a dealership service loaner. VIN is clean and it was not exactly cheap. - All notwithstanding the endless problems I am having.
Old Aug 3, 2021 | 12:04 PM
mikapen's Avatar
If M-B buys back a vehicle, aren't they required to disclose it in some way?
Old Aug 3, 2021 | 12:08 PM
Imanone's Avatar
Don't let the negativity get to you. They will either fix the issues or replace the vehicle. It's frustrating to say the least. Try to be patient which will be hard. It will get resolved to your satisfaction at some point.
Old Aug 3, 2021 | 06:26 PM
Jmarc's Avatar
e350
My 2020 GLE Lots of Break noise when releasing the breaks its like the break pads get stuck on the rotors the dealer replaced break pads and rotors and still same noise on when releasing the break now dealer says its part of breaking system on have 9,200
Old Aug 3, 2021 | 06:32 PM
  #32
nextmilenium's Avatar
2021 GLE450
I call BS on the dealer saying it's part of the braking system. Our 450 makes zero noise when braking.
Ask the dealer if you can test drive another GLE to see if the braking noise is there.
Old Aug 3, 2021 | 07:01 PM
  #33
mikapen's Avatar
Have you tried a few hard stops from speed to @20mph? (traffic permitting)
If you only dawdle around, the brakes can develop a glaze that is pretty annoying.
Try some aggressive stops before you judge the brakes.
Old Aug 4, 2021 | 06:01 PM
  #34
Jmarc's Avatar
e350
The Gm took it for a drive and said its the breaking system we have the amg package big drilled rotors
its sucks
Old Aug 4, 2021 | 09:57 PM
  #35
mikapen's Avatar
its sucks
Try doing some performance stops to see if it gets better.
Old Aug 13, 2021 | 05:13 PM
  #36
sub786sub's Avatar
GLE 350 , GLA 250 and Lexus ES 350
I have a 2018 GLE 350 with a V6 reliable engine ( no issues ) this will be my last GLE because of my reliability concern with the new GLEs. My concern with the 2019 and up model is the engine reliability. I also have a 2021 gla 250 which has the same 2.0 turbo engine which GLE 350 has. Only difference between the two engines is a little bit wider intake and bigger turbo give 30 hp difference. I believe that a small engine is too small for GLE. For GLA it is good but for GLE it might produce more problems in the long run ( 3 to 4 years) So make sure you guys have an extended warranty on those engines as I feel mule is given an adrenalin shot to run like a horse. GLE 350 is a heavy car and it can produce more stress on that small engine which was designed initially for smaller compact MBs
Old Aug 13, 2021 | 07:33 PM
  #37
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
As I recall, BMW is the only German car that has ever had engine problems of significance. If the 2 liter was going to be a problem then the 2 liter racing version with 450ish HP might be the one to watch. It’s apparently reliable enough that a 400+ HP version of it will soon come in a production car under the E Performance label. The GLE 350 engine has far more differences than intake and Turbo to get more power. There is a lot of info on Mercedes engine designs available if you do your homework…not always easy to find but it’s there.
Old Aug 14, 2021 | 04:59 PM
  #38
mikapen's Avatar
You need to drive one, before you think the 2 liter is underpowered. IMO, having spent a thousand miles in one, at elevations from 5,000' to 13,000 ft, I think ti's quite powerful up to about 90 - 95mph passing maneuvers.
And who's to say, maybe it's an engine designed for the GLE and also used in a GLC.
The hp/ lb-ft ratings for that size engine are pretty conservative, compared to other offerings on the market.
Old Aug 16, 2021 | 10:03 AM
  #39
mbgle's Avatar
gle
I have many of those same problems. Mine was not a CPO and was not one of the ones that sat for months outside waiting for parts. I enjoy the comments, while surely good intentioned, suggesting to have the dealership fix the gap dimensions and whistling side mirror etc.. is somewhat misguided. I have gone to my dealership several times to have noise issues fixed, (whistling, general wind noise, creaky driver door seals over ever bump) and they give the car back to me and say all normal. If this is normal for Mercedes they are in big trouble.
I'll likely keep the car for a little while longer and dump it. Never getting a Mercedes again.
Old Aug 16, 2021 | 10:06 AM
  #40
Imanone's Avatar
The whistling issue is well known and there is a service bulletin. Don’t let them tell you it’s normal. They have the parts to fix it for free.
Old Aug 16, 2021 | 10:13 AM
  #41
mbgle's Avatar
gle
Yea, I started the whistling thread on this forum a while back, I have taken it to my dealership and they tried the service bulletin fix which didn't work. I bought a crappy looking after market mirror covers which cut it down significantly so I'm just living with it now. The driver's door creaking after every bump is my new issue which they didn't even bother trying to fix. Frankly, I don't have time or the energy to bring this car back and forth to Mercedes. I have been to the dealership probably 5-6 times since I bought it to fix these issues. I'm not picky either, I have never had to do this with any other car before (Jeep, Audi etc..). I basically have given up and will live with these issues until a can get rid of it. I don't care what anyone says, this in not a well made car.
Old Aug 16, 2021 | 12:55 PM
  #42
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
The door creaking like a wooden ship is an easy fix. It’s caused by the rubber door seals. Push on the top of the door window frames (with the door closed ) and you can easily recreate the creak. Just go to the auto parts store and buy a $5 tube of silicone grease lubricant and apply it to the door seals… problem eliminated.
Old Aug 16, 2021 | 01:07 PM
  #43
mbgle's Avatar
gle
Yes! When I push the top of the door frame it does make the creak. OK, I'll try that fix. Thanks.
Old Aug 29, 2021 | 06:53 PM
  #44
CMFUSA's Avatar
Friends,
This is a related question to my V167 troubles (I'll post the full story later):
I am looking at the extended warranty (3yrs 75000m) on another GLE. Isn't there a member here in the forum who worked for MB and had the best quotes for these warranty extensions?
As far as I recall, you could buy them from any dealership and still be covered by MB anywhere in the US. Is somebody knows who that was, could you post his name please, so I can ask him for a quote?
Thank you
Old Aug 29, 2021 | 07:12 PM
  #45
Treihing's Avatar
2021 GLE 350 4Matic
There is but his pricing is not very good at all. Reach out to the Mercedes Fletcher Jones dealership in Newport, CA. They have decent pricing.
Old Aug 29, 2021 | 07:24 PM
  #46
chassis's Avatar
2017 GLE350 4MATIC
Use the search feature. A female salesperson was complimented by many users here for competitive warranty pricing.
The search feature will find it for you.
Old Aug 29, 2021 | 07:29 PM
  #47
CMFUSA's Avatar
Thank you! I found a gentleman by the name of Jeff Jackson in Louisville by using the search function. Also, I have contacted the recommended dealership in Newport, CA.
With regard to the other name, does "Erin Mahre" or "Cassandra Castro" ring a bell?
Old Aug 29, 2021 | 09:05 PM
  #48
cosmobenz's Avatar
2017 MB GLC300 & 2020 GLE350
We've used Jeff Jackson at MB of Louisville and found him absolutely great to deal with!!
Old Aug 29, 2021 | 09:33 PM
  #49
chassis's Avatar
2017 GLE350 4MATIC
Cassandra Castro is the name I remember from many posts on this site. I have had no dealings or connection with her.
Old Aug 29, 2021 | 09:41 PM
  #50
CMFUSA's Avatar
Thank you - I have sent her a message.
