Possible Heated Steering Wheel Problem...
If yours is switching itself off, then there's an issue.
It's possible the vehicle is detecting an electrical overload/fault, and therefore switching the circuit off. Hopefully the dealership can duplicate the issue and resolve for you.
Good luck!
Next issue, on the AMG wheel, it will heat nice and toasty to start then switch itself off. I am fine with that ( same thing on the GLK) but when I try to switch it on again, the indicator light says steering wheel heat is on but it will not re-heat - it's really weak second time around. Once again this problem does not happen with the GLK. I can reheat up the GLK steering wheel just fine. So my high falutin E63 has inferior steering wheel heat to my GLK in every possible way ???
Very frustrating....
