Is it tricky to put this car into neutral?
Old Jan 24, 2024 | 11:56 AM
RockChips's Avatar
2021 GLE350 and 2021 E450
Question Is it tricky to put this car into neutral?
It just jumps between D and R.
Old Jan 24, 2024 | 11:58 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
No, there is a detent before D & R. Stop pushing the stalk when you feel the detent.
Old Jan 25, 2024 | 09:58 AM
stktyz33's Avatar
MY2024 GLE 450
It is somewhat tricky to do from D->N and easier from R->N.
. I found that gently applying upward force on the shifter till it actually switches works somewhat reliably.You do need to get used to it, maybe practice a bit, otherwise your car wash experience will be rather stressful
Old Jan 25, 2024 | 12:35 PM
superswiss's Avatar
2019 C63CS
I occasionally accidently end up in N if I don't push far enough going from R to D or D to R.
Old Jan 25, 2024 | 02:03 PM
BenjaminKohl's Avatar
2014 Mercedes E350 4matic Wagon, 2018 Fiat 124 Spyder Lusso manual, 2005 Acura TSX manual
You should feel a second click putting it down to D or up to R. Just don't push past it, that's N.
Old Jan 25, 2024 | 02:37 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Yes it is!
Old Jan 26, 2024 | 09:57 AM
stktyz33's Avatar
MY2024 GLE 450
It doesn't "click" much going from D->N, it hard to feel the point of engagement. Going from R->N is easier as you do feel that middle position better. As for D->R, R->D, that's super easy, you just push it all the way up or down, no thinking involved. I actually like it way better than the center console gear shifters and got used to it like in a few days.
Old Jan 26, 2024 | 11:09 AM
Huh, I have an older car (2014 E Class) with the same shifter and have never had an issue feeling the click going down.
Old Jan 26, 2024 | 11:13 AM
stktyz33's Avatar
MY2024 GLE 450
You mean going "up" (D->N) ? D is the lowest position and you need to pull the lever "up" to go to "N". When you go "down", (R->N), you can feel it well. It doesn't "click", you just feel the resistance in the middle position once you hit it "middle floor". When you go "up", you can't feel much until you reach the "R", so you kinda have to "catch" it on these GLEs.
Old Jan 26, 2024 | 11:14 AM
Never had an issue going either way
