Windshield washer fluid pump?
Get rid of the fancy fluid / rain-x, the silicone additive builds up in the lines, pumps, nozzles and coats the level sensors over time like cholesterol in arteries. It might be working now but over time you'll have a full clog and always at the worst times.
To clear the system, empty out the fancy washer fluid, fill windshield fluid tank with 1 part distilled vinegar to 3 parts water, press the pump to give it a good flush, let the vinegar mixture sit in the lines for a few hours or overnight, flush the system out via windshield spray pump with clean water. Rinse off the car from all of the flushed fluids. Fill and only use OEM concentrate mix or the standard blue moving forward.
