New GLE Frustration
These are the finest engineered cars in the world, except that:
1. the windshield wipers do not return to the home position when turning off the car (every other car maker in the WORLD has this feature) 2. there is no "DUAL" temp control! (Some MB have it, mine does not, so I have to adjust two knobs every time I want to change the heat/ac) Really??? |
1. my cars didn't park the wiper if you just shut down in mid swipe. haven't checked the gle, but i will.
2. dual zone is standard. have you engaged "auto" mode and ensured "zone" control is not off (or on, need to look at button)? could be a service issue. good luck, ron |
My E class has the same wiper issue. The designers didn't think through it. :D.
If you have two knobs for climate control, then it should have a sync feature as well. |
I have two knobs, but no sync feature. There is a small button at the bottom of the driver's climate control, but it is stationary and appears to have no purpose.
i have 3 zone so there is a split switch where the recirc is. top "zone" bottom "off". just went out to check. when i move the driver side temp, the passenger side led moves in sync. when i move the passenger side temp, only it moves and my "zone" led lights.
the wiper does not park. continues to run when ignition is off, but once door opened, stops wherever it is. im in the usa if that matters. ron |
Originally Posted by CTPete
(Post 6794548)
Originally Posted by davezaristo
(Post 6794986)
its another option that you had to pay for I bet..
Originally Posted by rcsjr
(Post 6795069)
Should be standard. Push the "Auto" button. The led over Auto should be lit.
(Post 6796752)
No, he's talking about syncing temp. on both side by the press of a button, in which it is not a standard feature
(Post 6796934)
ok, i'm not clear. on my unit, once you press "auto" the driver controller adjusts the passenger side. if you then were to move the passenger controller, it breaks sync. you have to press "auto" to restart the sync. is this not happening on the unit in question? ron
(Post 6794425)
Full disclosure: I'm not an engineer nor do I do this. |
Originally Posted by YYZ-E55
(Post 6797621)
I always assumed that this is so dorky folk in cold climates can leave the wipers pulled away from the glass so they don't get iced in. The bonnet seems to extend beyond the wipers on some models making this impossible unless you can park the wipers further up the glass.
