GLE Class (W166) Produced 2015-2019
Just pictures!
Old Oct 19, 2019 | 02:47 PM
  #226
Bill Baird's Avatar
2019 C43 Coupe, 2017 GLE63, 2007 CL600, 2001 E430, 2002 S500, 2006 E350, 1985 SEC560, 2015 FIAT 500
I haven't a clue. The backspacing is the standard backspacing is on the OEM coupe wheels.
Old Oct 19, 2019 | 02:49 PM
  #227
Bill Baird's Avatar
I agree and removed the wheels. I ended up purchasing 20" GLE43 wheels. I had them on my '17 GLE43 and they look a lot better.
Old Oct 24, 2019 | 10:12 AM
  #228
themaxx25's Avatar
GLE 400
Offset?
Do you have a picture of it with the 20" GLE43 wheels? I was thinking maybe 21" would be better, or to LooseGoose's point, maybe not so wide of a wheel...10" maybe.
Old Oct 29, 2019 | 04:49 AM
  #229
Loosegoose's Avatar
Ml350 w166
front 21x10 et 38 and rear 21x11 et 38
Old Oct 29, 2019 | 10:05 AM
  #230
threeMBs's Avatar
Only MBs - the best or nothing
Do you have shots from different front/rear angles? The poke (especially in the back) still should be there even with added fender flares.
Old Oct 29, 2019 | 10:32 AM
  #231
Loosegoose's Avatar
Ml350 w166
Old Oct 29, 2019 | 10:54 AM
  #232
threeMBs's Avatar
Surprisingly, the rears look perfect (or very close to it). Those fender flares definitely help a lot. How wide are they at the widest point up top? 1" or more? Are the tires in the back 295 or wider?
Old Oct 29, 2019 | 11:24 AM
  #233
Loosegoose's Avatar
Ml350 w166
325 rear , 285 front , flares are about 20mm just a bit under inch wide
Old Oct 29, 2019 | 11:44 AM
  #234
threeMBs's Avatar
Do you have a similar angle shot of the front? TIA.
Old Oct 29, 2019 | 12:09 PM
  #235
Loosegoose's Avatar
Ml350 w166
No but I can take couple of shots tomorrow , but no poke in font
Old Oct 29, 2019 | 12:35 PM
  #236
Loosegoose's Avatar
Ml350 w166
One more from rear
Old Oct 29, 2019 | 01:30 PM
  #237
Loosegoose's Avatar
Ml350 w166
Fr
front
  #238
Loosegoose's Avatar
Ml350 w166
Front
Old Oct 29, 2019 | 01:32 PM
  #239
Loosegoose's Avatar
Ml350 w166
Rear
Old Oct 29, 2019 | 01:59 PM
  #240
threeMBs's Avatar
Front
Looks great, both front and rear. Very good info as a reference point: so without fender flares for rear only, 10" wide wheels with offset of about et45 or 11" wide wheels as above with offsets of about et57 (if there's no inside rubbing). Bookmarked it. Thanks.
Old Oct 29, 2019 | 02:33 PM
  #241
Loosegoose's Avatar
Ml350 w166
Basically you can use gle coupe wheels when you add flares
Old Oct 29, 2019 | 02:50 PM
  #242
Loosegoose's Avatar
Ml350 w166
there is about 1 inch space inside with 10” wide wheel with et 50
Old Oct 29, 2019 | 03:32 PM
  #243
threeMBs's Avatar
OK then 11" wide wheel with 325 tire and et60 is about the widest wheel/tire with the highest offset possible that can fit the rear (not a suggestion, just a reference point) without inside rubbing. This will also place the outside edge of this hypothetical combo exactly where OEM AMG's 10" wide et46 wheel with 295 tire is.
Old Oct 29, 2019 | 06:58 PM
  #244
Bill Baird's Avatar
I really like the look. Are the flares OEM?
Old Oct 29, 2019 | 11:26 PM
  #245
Loosegoose's Avatar
Ml350 w166
No, these are replicas
Old Oct 31, 2019 | 05:44 AM
  #246
amusa's Avatar
16 GLE400 4matic
The family SUV
Old Oct 31, 2019 | 10:36 PM
  #247
chassis's Avatar
2017 GLE350 4MATIC
Looks great!
Old Nov 5, 2019 | 04:49 AM
  #248
amusa's Avatar
16 GLE400 4matic
I'm going to talk to my friend over at Mercedes (over 25 year MB master tech) about getting a new firmware (My vehicle production date is on November 10, 2015). I'm thinking to get that ECO bypass module that my friend told me about. I can't get used to the motor shutting down and it's driving me crazy to push that button every time.
Finally the weather liner mat came in but still waiting on the cargo weather liner (In transit). I'm looking into the puddle light for the running board. If anyone has direction of the PDF file please post it.
Old Jan 6, 2020 | 04:02 PM
  #249
phamq1979's Avatar
W205, W124, W166
Old Jan 6, 2020 | 09:09 PM
  #250
chassis's Avatar
2017 GLE350 4MATIC
Nice looking GLE400, like the chrome hood ribs!
