GLE issues
I had a loaner GLE 350 and experienced the same issue, but only when trying to lock the car. It always worked unlocking and when starting the SUV.
while reading this thread, i asked my wife to check her MB connect app
she asked me "what does it mean when it says 'Boot open'" and showed me the icon
Got worried that the trunk was left open and went down to the garage... to find that the car was locked and secured
i unlocked and locked the car again and the boot open icon went away
Going to have to keep an eye on the app and see if this is a common occurrence or not
So my wife has been having problems unlocking her 350 - this is her 3rd ML so it's not user error, the car simply does not respond to the presence of the smart key in he bag about 50% of the time.
Saw it happen in the garage yesterday morning - suggested she shake her bag as someone here pointed out - it worked.
Happened again later in the day - this time shake-to-wake didn't work.
This looks like a regression - the old keys always worked (and were smaller too) - hope this is an easy fix for MB - annoying / safety issue
found a new issue.
when i drive on the free way two days ago, suddenly all the parking sensor start beeping and warning me gonna crush in something, after 5 seconds all back to normal. it was happened before when I'm driving in the heavy rain, i think maybe the rain caused it. but this time was a very sunny day, and other cars even close to me.
found a new issue.
I'm havig a ton of issues with keyless go not "locking" doors. After a service call they think the keys are going to sleep and not waking up. Sure enough, if I just up and down before I try to lock the doors at the handle IT WORKS. So, how many of you out there are having to jump up and down to lock your doors!? This is rediculous.
-Terry
#32
Wipers-Heavy rain the last two days and the wipers track great but they stick when the rain is light. By stick I mean they aren’t smooth and hang up causing a chatter. Best at cleaning the windshield that I’ve ever owned but that drag can’t be good for the wiper motor. First I cleaned the wiper and got a lot of black residue. That didn’t fix anything so I dried them, cleaned again and applied Rain X. That worked for a while but they started to stick again. With the Rain X I didn’t need to run them in light rain . Has anyone else had anything similar happen?
-Terry
#33
found a new issue.
#34
I've had a couple times where the doors don't lock automatically when touching/pressing the "button" (pad?) on the handle after shutting the car down. The fob lock button worked to lock the car, though. The "locking when touching the pad" has worked all subsequent times.
-Terry
-Terry
so when i gave it a few tries, i figured out what she was doing wrong
the little square on the outside of the handle ONLY LOCKS
if you touch the inside of the handle, the door unlocks
see if you/your wife have been touching the outside when trying to walk up and unlock the door
Vic Miscio (08-22-2019)
#35
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
Was the nav system being used ? I had nav turned all the way down and could not figure out why the music would cut out was the nav spewing directions that i could not hear cause i turned it all the way down
#36
Wipers are horrible. Chatter is bad. Cleaned them with soap and water. Used alcohol to wipe down and they were good for 20 minutes. I would like to know if Rain X helps I suspect it will not as my carwash has this as a final spray.. I had an Aquapel done on my 2015 and had to have it removed. Took the glass shop an hour to get it off. The best blades I have ever used are PIAA but finding them for this car has proven futile. The PIAA guides I have seen go up to 2004.
#37
Also started a thread asking if anyone knows. Someone replied but not confirmed.
-Terry
#38
#39
-Terry
-Terry
#40
Talked with PIAA today regarding wiper blades. The most recent data they had was for a 2018. I ordered them from Amazon and will report back.
#41
#43
I did a 200 mile drive yesterday with rain most of the time - we had just picked up the car on Sat., and as you say, the "chatter" was really bad, although after almost 3 hours of driving with the wipers on most of the time, their was notable improvement (smoothness) in their operation. Will wipe them down and see how they perform next time before raising the issue with our dealer.
#44
2023 GLC 300 4MATIC
I’ve had mine almost a month now. Wipers were chattering like crazy early on. Now after being used they work perfectly. Perhaps the original rubber needed to wear and soften a bit with some use.
Other than that, no issues. Love it more each day.
#45
Received 1,168 Likes
2020 GLE 450; 2023 BMW M2 Coupe
Waiting for roadside assistance
Pulled over to make a calll and car won’t restart. Multiple error messages. Tried key in emergency position. Roadside coming. Grrr.
#46
Stranded
So car would turn on, but not start. MBUX working. Multiple error messages - "Blind Spot Assist inoperative," "Parking brake," "Malfunction - see Owner's manual." Jump start did nothing. Disconnecting and reconnecting battery got it started again (when in doubt, reboot!). At the dealer now; will report back. Hopefully, just a software issue.
bad habit (06-20-2019)
