Exhausting Exhaust question please
Old May 28, 2025 | 11:57 AM
SilverDameon55's Avatar
16' GLE63S AMG
Hey everyone, so I've got an exhaust question and I know it's one that's been discussed I'm sure, loads of times but I can never find a definitive answer nor can I find the answer relating to my specific model, so I thought I would just ask it here.
I've got the 2016 gle63s suv version and I'm looking to make the exhaust not only a little more aggressive and deep but I also want to make the crackles and pops more profound. Some power gains would be great and always accepted too. What I'm between is either the muffler delete or the resonator delete or both. What's going to give me that deeper aggressive sound with some extra pops and won't throw any codes?
Also if the resonator delete is the way to go, would I replace it with straight pipes, X pipe or H pipe?
Thanks everyone for your input.
Old May 28, 2025 | 02:42 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Curious. Do you have the OEM Standard or OEM Performance exhaust option?
Old May 28, 2025 | 03:30 PM
16' GLE63S AMG
Good question....I like to think I have the performance exhaust but how would I know? I mean the sound is decent as it is and better in Sport+ but how would I know if it's the performance vs standard? I figured all AMGs would have performance exhaust....
Old May 28, 2025 | 05:15 PM
E55 KEV's Avatar
Veteran: Air Force
Pops and Burbles only come in Sport+ mode.
W166 GLE63 Non Performance Exhaust:
W166 GLE63 Performance Exhaust:
Old May 29, 2025 | 03:20 PM
16' GLE63S AMG
oh wow I didn't realize the differences. I just checked mine and I have the performance exhaust! So I guess I don't have resonators then?
Old May 29, 2025 | 09:05 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
H pipes on a turbo vehicle and X pipe on a NA engine. A turbo engine will lose power with an X pipe as there is no scavenging in a turbocharged engine. Remember, you want the exhaust to leave the fastest with least resistance in a turbocharged vehicle.
Old May 30, 2025 | 10:17 AM
16' GLE63S AMG
Yeah that makes since given turbos utilize exhaust and the more flow the better. With mine having the performance exhaust, it already has the H pipe setup so should I consider upgrading the down pipes more than removing the muffler? I'd like to definitely wouldn't be opposed to a little more turbo noise lol.
Old May 30, 2025 | 11:27 AM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
Wrong but it's ok.. Every internal combustion engine benefits from exhaust scavenging even before the turbo it's called valve timing and overlap when tuning for a turbo engine. H is for exhaust tone, a X pipe exhaust has less restriction in the flow, less back pressure. NA or turbo flow matters.
Old May 30, 2025 | 10:19 PM
BlownV8's Avatar
An X pipe is after the turbo so no savaging. Should have been clearer on the scavenging but I know of no one who puts one before the turbo but not discounting some builder who has. Wrong on flow, so, so, wrong on an X pipe flow on a turbocharged engine. You really need to do your research. The X pipe on a turbocharged engine can CREATE restriction if the exhaust gasses are crashing into each other as most X pipes do. H pipe is for sound equalization and offers ZERO performance benefit on a turbocharged engine. X pipe reduces power on turbocharged engine.
Old May 30, 2025 | 10:49 PM
BlownV8's Avatar
Downpipes would be good for increased flow and removing the rear muffler will produce more sound. The turbochargers do a pretty good job of reducing the sound so without the muffler it should still be fine. It will be a little loud at startup but, again, it will be fine. I ran no mufflers with downpipes in my Bi-turbo V12's and the sound was sublime.
