How to cross reference MB wheels?
I would like an additional set of MB wheels for snow tires, but most of the listings on Craig’s list / newspapers only tell you model and year. Is there a web page or cross reference that will allow a newbe to identify what other MB models had or have wheels that will fit the GLK without knowing the diameter, offset & hub size. Or is this the first use of the size?:confused:
Hope this helps.
As far as I can determine, most OEM MB wheels will fit however, the offset is the determining factor. https://mbworld.org/forums/glk-class...eel-specs.html Cheers.:) |
I give is there an older MB with the correct offset to fit the GLK?
