MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   GLK-Class (X204) (https://mbworld.org/forums/glk-class-x204-94/)
-   -   Help! Sunroof won't close. (https://mbworld.org/forums/glk-class-x204/439741-help-sunroof-wont-close.html)
mark896 Mar 19, 2012 12:58 PM
My wife just called me from work and says her sunroof will not close. When she pushes the button it inches forward but then goes back. I told her to check the tracks to see if anything is in the way but she says she can't see anything.
Where do I start?:nix:
2010 GLK 350 4Matic with 22,000 miles.
venchka Mar 19, 2012 01:20 PM
Dealer. Before it rains. Good luck.
Wayne
mark896 Mar 19, 2012 01:34 PM
That's what I was afraid of
venchka Mar 19, 2012 01:45 PM
I had a similar event with my old Volvo. Driving to work. Started to sprinkle. Put the driver's window up. It went up about two inches and stopped. I drove straight to the dealer. Beat the rain.
Your sunroof does sound like something may be in the way, binding or lack of lubrication.
Wayne
mark896 Mar 19, 2012 01:53 PM
Just looked at it, certainly appears lubed, can't see anything in the way.. She's about to take it to the dealer which is 1.5 hours away :(
At least it's a certified pre-owned.
venchka Mar 19, 2012 01:57 PM
With lots of original warranty left. Sorry about the distance. We are almost in that same situation.
Wayne
big_aristotle Mar 19, 2012 02:01 PM
Here is a the direct text from the Owner's Manual. I hope this helps!
Problem: the sunroof cannot be closed
and you cannot see the cause.
Warning!
You could be severely or even fatally injured
when closing the sliding sunroof with
increased closing force or if the antientrapment
feature is deactivated. Make sure
that nobody can become trapped when
closing the sliding sunroof.
If the sliding sunroof is obstructed during
closing:
Immediately after the sliding sunroof
blocks, pull the
switch in the
overhead control panel down to the point
of resistance and hold it until the sliding
sunroof is closed.
The sliding sunroof is closed with increased
force.
closing again:
blocks, pull the
switch in the
sunroof is closed.
The sliding sunroof is closed without the
anti-entrapment feature.
Warning!
Pressing and holding the sliding sunroof
switch to close the sliding sunroof
immediately after it had been blocked two
times will cause the sliding sunroof to close
without the anti-entrapment feature for as
long as you hold the switch.
mark896 Mar 19, 2012 04:51 PM
Thanks for that, but we tried holding the switch down for a long time. She just went to the dealer and they had to do a 'reset and resynchronize', whatever the hell that means. It works now. :nix:
MBNA109 Mar 19, 2012 05:01 PM
Glad it worked out. I wonder what happens in the warranty process if it had rain...:nix:
mark896 Mar 19, 2012 05:11 PM
Sounds to me like they'd be replacing the interior. None of it was our fault.
SHAUNA123 Nov 28, 2015 05:49 PM
Panoramic sunroof wont close completely!!!
How do I get my sunroof to close completely? Don't understand the directions in manual to reset it. How much does it cost at the dealer to reset it???
107123210 Nov 28, 2015 09:24 PM
This video explains the synchronization. Haven't looked but it too should be in manual.
The instructions posted earlier appear to be for how to close a sticky sunroof. Seems they have a safety built in in case you get your head or arms or something in the opening while it is closing. Sticky rails would trigger same safety.
By the way, after two Benzes with sunroofs, I specially ordered our 2014 GLK250 without a sunroof! Slow learner, I am afraid.
cindyclk Nov 28, 2015 09:48 PM
Basically you just move the window an inch or 2 at a time until it fully closes. If you keep holding the switch, it will reverse itself when it hits it's electronic limit. What the resynch is is resetting where that electronic limit is set.
Once it is closed, you then hold the switch for 5 seconds. That sets the electronic limit at that spot. Then you move it to the full open position and hold for 5 seconds...resynch complete.
The same thing works for the limits of how far your windows open and close and also your seat limits.
© 2026 MH Sub I, LLC dba Internet Brands
