Review: Win Power Headlights (Lighting Package Replicas)
Overall thoughts: The lights are comparable to OEM quality at a glance. They are solidly built and they are plug and play like they described. You won't get the auto leveling features or any of the fancy features that come with the lighting package. These headlights basically only give you the look (LED DRLs, LED turn signals, projectors, and HIDs). Pricing isn't as expensive as the lighting package but it wasn't cheap either. I was relieved there was a good enough quality option as my wife kept regretting not getting it from the dealer. The cut off is pretty clean, but it's hard to tell from the blurry picture. Hope this post helps others that are on the fence. While I'm not sure on the longevity of the headlights, they look and feel solid almost OEM. The only downside so far are the errors I've received below. I haven't had time to look into them too much but hopefully there's an easy fix.
Regarding the errors, I've had no luck. The vendor has been very helpful and will be sending a higher rated resister to see if that will help. In the mean time, I've tried to reset via an OBDii reader which didn't work because it didn't see the error at all. I tried scheduling an appointment with Mercedes to which they said they could program the car to try looking for the LED bulb rather than the halogen bulb, but I would need the LED part number which I didn't have. They wanted to charge $145 to reprogram it but I didn't want to risk it not knowing if it will even fix the error. Right now I'm awaiting the vendor to send me the new resistor to test it out. I'll update once received. Not sure if anyone else will have better luck with Mercedes but they were unhelpful during my visit.
We just purchased a used GLK350 and it doesn't have the lighting package either. It's unfortunate the headlights cannot simply be 'swapped' out. As pricey as these Win Power headlights are I'm actually very interested in buying them. Aside from the price, I'm hesitant to move forward with a purchase due to the errors you mentioned they're giving. Were you ever able to resolve these errors?
I appreciate the response and any advice. This has been quite a process and my car needs to be smogged next month.
