Help me please (GLK Steering Wheel Conversion)
Old Feb 15, 2018 | 08:28 PM
nismogtr10's Avatar
G63
Exclamation Help me please (GLK Steering Wheel Conversion)
Hi!
i bought a used steering wheel of 2013 c300 and i installed on my glk 2012 but none of the button seem work, , horn and buttons doesn't work, the airbag is ok (NO scan code) . i already see other threads and its compatible maybe is the contact plate that i have to replace?
THANKS
Old Feb 15, 2018 | 10:02 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
so looks like you are using a 172-460-59-03 flat bottom steering wheel with a pre-facelift GLK. Looks like you need a new steering column from a newer W204.
Old Feb 16, 2018 | 12:17 AM
nismogtr10's Avatar
G63
Originally Posted by JohnnyC
so looks like you are using a 172-460-59-03 flat bottom steering wheel with a pre-facelift GLK. Looks like you need a new steering column from a W166 166-900-96-02.
I read other thread that you only change the steering column to function the control lights, i guess i need another contact plate?
Old Feb 16, 2018 | 01:49 AM
JohnnyC's Avatar
No the steering column is the only part need. the Contact plate is backwards compatible. The steering column doesn't work with new steering wheels.
Old Feb 16, 2018 | 07:45 PM
nismogtr10's Avatar
G63
thanks to all , i only replace the new chip for the old one. all good
Old Jul 20, 2022 | 04:55 PM
foxakias's Avatar
GLK300 4MATIC
It was plag and play or need something more?
