Brake torque specs
Old Mar 27, 2018 | 05:11 PM
JamesZ's Avatar
GLK350
Brake torque specs
I am looking for torque specs for my 2010 GLK350 4Matic (X204)
Front Brake Caliper Guide Pin:
Rear Brake Caliper Guide Pin:
Front Brake Caliper Bracket:
Rear Brake Caliper Bracket:
Wheel Bolts:
Thanks much!
Old Apr 16, 2018 | 03:03 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Wheel bolt:
M14 x 1.5, radius seat
17mm hex, Mercedes 17mm key, or lock key socket
150Nm ~ 110 ft-lbs
Front brake caliper mount external torx flange bolt:
M14 x 1.5 - 45mm
E18
000000-005639
180Nm ~ 133 ft-lbs
Rear brake caliper mount hex bolt:
M12 x 1.5 - 35mm
18mm
124-421-05-71
120Nm ~ 88.5 ft-lbs
Front floating caliper guide pin hex flange bolt:
M10 x 1.25 - 31mm
15mm hex + 20.6mm flat
000-421-53-74
29Nm ~ 21 ft-lbs
Rear floating caliper guide shoulder screw:
7mm hex key
000-421-08-18
34Nm ~ 25 ft-lbs
Brake disc retention screw:
M8 x 1 - 12mm
T30
220-421-01-71
10Nm ~ 7 ft-lbs
Right brake caliper sensor external torx flange bolt:
M6 x 1 - 20mm
E10
910143-006002
8Nm ~ 6 ft-lbs
Front hub axle flange bolt:
M16 x 1.5 - 60mm
E24
000-990-75-03
160Nm ~ 118 ft-lbs, loosen,120 Nm ~ 88.5 ft-lbs, then 90°
Rear hub axle flange nut:
M26 x 1.5 - 17mm
32mm or 1¼"
000-353-13-73
350Nm ~ 258 ft-lbs, then stake
Rear wheel bearing carrier flange bolt:
001-990-42-03
70Nm ~ 52 ft-lbs
Front outer tie rod flange nut:
M14 x 1.5
000000-008261
50Nm ~ 37 ft-lbs, then 60°
Front tie rod jam nut:
M14 x 1.5
308673-014001
65Nm ~ 48 ft-lbs
Front inner tie rod assembly:
41mm octagonal
212-330-28-03
110Nm ~ 81 ft-lbs
Old Dec 24, 2021 | 07:01 PM
joseph espinoza's Avatar
Mercedes 2012 C350 coupe m276
Originally Posted by JohnnyC
Wheel bolt:
150Nm ~ 110 ft-lbs
M14 x 1.5 - 45mm
E18
000000-005639
180Nm ~ 133 ft-lbs
M12 x 1.5 - 35mm
18mm
124-421-05-71
120Nm ~ 88.5 ft-lbs
M10 x 1.25 - 31mm
000-421-53-74
29Nm ~ 21 ft-lbs
7mm hex key
000-421-08-18
34Nm ~ 25 ft-lbs
M8 x 1 - 12mm
T30
220-421-01-71
10Nm ~ 7 ft-lbs
M6 x 1 - 20mm
E10
910143-006002
8Nm ~ 6 ft-lbs
M16 x 1.5 - 60mm
E24
000-990-75-03
M26 x 1.5 - 17mm
32mm or 1¼"
000-353-13-73
001-990-42-03
70Nm ~ 52 ft-lbs
M14 x 1.5
000000-008261
M14 x 1.5
308673-014001
65Nm ~ 48 ft-lbs
41mm octagonal
212-330-28-03
110Nm ~ 81 ft-lbs
torque spec rear axle nut
Do anybody know the torque spec for the rear axle nut on a 2012 mercedes C350 coupe base model rwd
