GLK 350 losing brake fluid
BTW, the pedal has finally started to get spongy, just like it would be a master cylinder failure.... But where is the fluid going???
As the pads wear the pistons in the calipers move outward and stay there so more brake fluid stays in the calipers instead of the reservoir. So as the pads wear the level goes down. If the level goes down fast and you have to keep refilling then you have a leak. If it's slow and consistent then it is normal.
If you do have a leak and a spongy pedal it could be leaking out the back of the master cylinder into the vacuum booster. At some point I would expect a visual indication of fluid.
