2013 GLK 250 4matic front driveshaft replacement
Hi Everyone!
My first Mercedes and not a great experience :(... I just purchased a 2013 GLK 250 with 100k miles. Against my better judgement i didn't purchase warranty and after 1 week of driving my front driveshaft broke :(... Dealer wanted to charge me $3k just to change the front driveshaft. No way does it cost 3k to change a driveshaft i thought and went to eBay to purchase a driveshaft to install on my own. I'm stuck and need help! I can't get enough clearance to squeeze the driveshaft over the differential to slide in to the front then pull it back so splines of the shaft is connected. The huge cat takes up a lot of space and i can't seem to maneuver around it. I removed the transmission crossmember to drop the transmission as low as i could without removing it so i can try and slide in the driveshaft but no luck. This shouldn't be that hard to replace what am i doing wrong? Any help welcome! Thanks! |
Unfortunately I can't give you advice but sometimes the simplest job on a Mercedes can be a intricate process. Perhaps you could search for a workshop manual or possibly a YouTube video. Best of luck to you.
did you replace this shaft? where did you source the replacement? thanks
Originally Posted by glkoffroad
(Post 8513077)
I purchased it from Ebay. I think it was this one... https://www.ebay.com/itm/19289686215...AAAOSwO8tcv27H Works great, a bit bulkier than the OEM. I tried to install myself but failed so I took it to a local shop to get it installed. Let me know if you were able to install it yourself and how'd you do it? Thanks! |
If your in Chicago I can get you to a guy that can help, my total cost was near 500$ , yes a stupid hard job
2 Attachment(s)
Originally Posted by ChetTheTech
(Post 7747898)
Hi Everyone!
thanks dzl benz. I have had my dpf in and out before for servicing. I didn't find it too difficult on my hoist. it seems like a few people have used the glk350 shaft in there glk250 and say it works but I'm not sure. I was told they are different lengths which I confirmed. it appears as though the 250 shaft is 0.25" longer than the 350 shaft. so I would think the 350 will go in the 250 but not vise versa. I am very hesitant to do so but am considering it since the 250 shaft doesn't see available in Canada unless its oem. at $1400 for the part. ouch. the glk350 shaft seems to be available here aftermarket. can anyone confidently confirm if the 350 shaft is usable in the 250. again the 250 shaft is 0.25" longer so I would not put it in the 350 which is not my concern since I have a 250. if anyone wants to confirm this I got my information from dorman shaft lengths.
I got mine at FCP euro for about 250$ contact them they offer lifetime warranty
Originally Posted by Mmr1
(Post 8513808)
Contact fcp euro , they will help you the best.
fcp doesn't have it. I called. Im going to assume you have a glk350. I'm still curious if anyone can confirm that the shorter 350 shaft will work in the 250
(Post 8513870)
The transfer case is bolted to the back of the transmission which is mated to the engine. The front differential is bolted to the oil pan with a driver-side CV axel going through the oil pan. So the entire drivetrain unit is rigid and the only play would be at CV shafts connected to the suspension. That's just how I think but I can't confirm from the experience if the two are interchangeable 100% Here is a good diagram that might give you an idea about tolerances (looks like it's from MBWorld as well) : https://cimg2.ibsrv.net/gimg/www.mbw...ae10a6908.jpeg |
Just finished the drive shaft replacement on the GLK 250. First you have to clear everything around the drive shaft. Start with the DPF, remove/disconnect all sensors, including the one to the transmission. The hardest part here is removing the clamp between the catalytic converter and the DPF. I did it from under the car. Extend the ratchet with a pipe to get to the clamp. Remember/record the position of the clamp. Will explain later how to install it back. Go from the top and remove the intake filter housing and put it on top of the engine. Disconnect whatever is on the way . Remove the 3 bolts that hold the rear bracket on the filter housing and loosen the 8mm bolt at the back that holds the 3 little tubes and remove the tubes from the bracket. remove the nut that holds the Catalytic converter to the exhaust manifold . Remove the clamp to the turbo. At this point it is loose and lift it up as high as possible to give more clearance for the drive shaft. Then go under the car again and remove the heat shield around the drive shaft. The rear top bolt is the hardest ( use fingers to locate) . Now you have clearance to remove the 4 bolts that holds the drive shaft. Mark the position of the drive shaft -letters D and A . Remove the rear crossmember that holds the transmission mount and lower the transmission as much as it goes. Secure with something. Push the drive shaft up and forward- should come out of the transfer case. Wiggle it and take it out. If you are using after market drive shaft get a small file ( semicircle) and file each groove at the splines side. ( 3-4 strokes on each side is enough, just to remove the imperfections. Otherwise you can not insert it) . Use some grease to make it easier. At the transfer case use a prybar to move the transmission away from the drive shaft and use 2x4 to secure the clearance. Insert the new drive shaft toward the engine and up. Install the rubber boot on the transfer case side. Then insert the splines side and the rubber boot should come in place . Then will be easy to install the bolted side. Some manuals recommend removing the collar with the 5 bolts, if you need to. Personally i had it removed. Now the drive shaft is in place and it is time for the small heat shield. Will be easier to install then to remove. Next position the catalysator loose and install the clamp on the down pipe on catalysator side and secure it with one rubber band just on the edge of the pipe( wrap were the bolt goes in to hold it in place). Go under the car and install the DPF. Go back on top and position the catalysator to sit properly on top of the DPF to align the pipes. Then push carefully the clamp down and should click around the two pipes. the rubber band should keep it tight enough .until you install the bolt . The bolt was easier from under the car. Tighten the clamp and move to the clamp after the dpf to the muffler and tighten it. Tighten everything under the car and install/ reconnect all sensors. Tighten the transmission mount as well. Go on top and tighten the clamp that holds the 3 small tubes behind the catalysator and reinstall the aluminum bracket. Install the last clamp on the catalysator to the turbo and reconnect all sensors. Reinstall the filter housing and you should be good to go.
