Auxillary Battery
2014 GLK 250
Auxillary Battery
I am getting an Auxillary Battery Malfunction message. Battery has probably gone bad, its 5+ yrs old. I want to replace, but CAN'T FIND IT! Help. Its not in back on the passenger side, I checked. Where else can I look?
AZDan
AZDan
2014 GLK 250
I'm pretty sure the GLK 250 does not have an auxilliary battery. Those were needed (and thus installed) only on gasser models that have the automatic Stop/Start feature, which as far as I'm aware, the Bluetec does not utilize.
The only thing you'll see in the trunk under that liner is the DEF tank filler and subwoofer for the the HarmanKardon sound system, if equipped. We (in the U.S.) also have no spare tire, because the DEF tank takes up that space. Instead MB put "run-flat" tires on GLK250s.
You might just be needing a new main battery, if you're on the original 2014 one.
Is it a GLK?
