Brake fluid
I want to flush the fluid. I have 2 liters of genuine VW/Audi fluid on hand, which is Dot 4. The boiling points match Mercedes specs. I would think that this would be very quality fluid since Audi’s also cost a lot. They very well could use the same part suppliers. Mercedes specs aren’t listed on it, but why would they test for that? I hate to go buy two liters of another fluid when I have this on hand. Has anyone used it before in a Mercedes? I find it hard to believe it will ruin the brake system.
Thanks. |
Mercedes GLK requires brake fluid DOT 4+, I wouldn't speculate about this, it's not expensive and you need only 0,5 litre.
I agree with Marek. If the fluid does not specifically say that it meets the Mercedes specifications then don't use it. You can't just guess that because it is expensive it must be good and compatible. While the boiling point may be ok, how do you know that it does not contain chemicals that could prematurely corrode or otherwise compromise the materials used in the flexible seals? I would rather spend a little bit of money on proper fluid than suffer blown out caliper seals down the road.
Agreed; something that needs doing only every 2 years isn’t where I’d try to skimp, especially being a safety issue.
Use the MB spec stuff and save your VW/Audi fluid for those applications. |
I just ordered Pentosin Super Dot 4 and will use it. Thanks.
And is there a procedure to bleed the ABS pump that can be done DIY?
I'd use whatever DOT4 you have. There is no magic about it.
Originally Posted by FullMoonParty
(Post 7791670)
Originally Posted by Marek_Norway
(Post 7791014)
Originally Posted by formerjeepguy
(Post 7791451)
