15 GLK250 won’t start or try to turn over. New battery installed.
Old Dec 28, 2022 | 08:24 PM
GLK250Dude's Avatar
2015 Mercedes-Benz GLK250
Had the car parked in -40 for a couple days. When it warmed up to -20 thought I’d finally try to start it.
Warmed the car up with an external heater. Charged the battery. Tried push button and ignition key turn, still No start. Doesn’t even sound like it trying to start, not getting the usual cranking noise or clicking noises.
Replaced the Battery with a Brand New One. Same thing happens with New battery, still won’t start it.
Push button and Turn key ignition used, and it sounds like it’s not even trying to start. No car starting sound or clicks or anything?
Out of ideas and not close to any dealership since I am out of town. Any suggestions? What should I check next?
Old Dec 28, 2022 | 08:47 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Any "messages" on the dash or odd readings ?
You say you charged the battery ... does it provide any feedback ?
Old Dec 28, 2022 | 09:08 PM
GLK250Dude's Avatar
No messages except the ones I’m used to (blind spot detect inoperative, parts on order at Mercedes). Had the battery key low message as well, but we replaced the battery key during our trial and error so that’s gone.
we charged the old battery (Mercedes OEM), the battery charger said it was at 90% capacity but don’t know how accurate. The parts store said the old battery was done. So we took old battery out and just bought a new one and tried that. Installed the new one to rule out any battery issues, and still no starts
Old Dec 28, 2022 | 09:44 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Did you charge the new battery?
No starting sounds at all would point more toward a start inhibitor or something. Does the dash light up, and the gauges move when you turn the key on? Do other things. like the radio, work as expected?
Old Dec 28, 2022 | 09:51 PM
Mmr1's Avatar
2013 glk 350
Most new batteries are not fully charged when sold, stores are lazy. How do you know it’s fully charged ? The mb battery was AGM and needs a charger with an AGM cycle to get fully charged. Is the new one AGM, does your charger have that cycle? I have an 80$ Sears charger with an AGM cycle that won’t get my batteries above 85%. I’d start making sure it’s charged . What is its voltage ?
Old Dec 29, 2022 | 01:09 AM
A1H2O4U's Avatar
1999 SL500, 2018 Jeep Grand Cherokee, 1969 Dodge D-200, 1970 Dodge D-100, 1970 Chrysler Newport
When you installed the new battery, did you remove the protective plastic caps from the posts before attaching the cables?
Old Dec 29, 2022 | 09:07 AM
John CC's Avatar
Old Dec 29, 2022 | 03:32 PM
Mmr1's Avatar
2013 glk 350
Most causes of problems are a weak undiagnosed battery
Old Dec 30, 2022 | 09:57 PM
KanataSteve's Avatar
2013 GLK350 Canada
When the ignition is turned on, does the radio and navigation work? If not, the key isn't turning the car on fully (yup, I remember the display lit up and said low key battery).
Can you unlock the doors with the key fob? (Hopefully the key battery isn't installed upside down - did that once myself, eye roll).
Just for curiosity's sake, some old skule checks;
Give all the relays a few good taps with a screwdriver handle (don't break them though!) in all fuse blocks since you mention it still is -20 degrees where you are. Sometimes relays stick in *very* cold conditions.
Can you measure voltage going to the starter, and can you measure voltage to the switch side of the starter when turning the physical key to the start position? Make sure to use long meter leads and don't be under the car when starting.
Clean the battery connections.
Clean the battery *body* ground connection.
Tighten the starter mounting (ground) bolts.
Is there an auxilliary battery in this model/year? They cause some *weird* things. If suspect, use another car battery in its' place. Might be under a cover in the spare tire area.
This checks 1) good connection of battery to starter, 2) good connection of battery voltage to switch in the starter, and 3) eliminates the key's push button wireless connection.
Next step, heated garage overnight if possible?
