2011 GLK350 intermittent A/C issue
Sometimes the A/C stops blowing cold are. I stop, turn the car off, turn it back on and the A/C works again. Any advice on what this might be? Thanks!
Low Freon ? I’ve never done this , so I don’t know the negatives, but auto stores sell Freon with pressure valves attached. Find your Freon make, label should be under the hood and buy the correct Freon. Follow instructions, don’t overfill!
Also To get it colder, and remove mold and the smell, clean the coil, it’s done with a special cleaner in a spray can with a hose the goes up the drain tube from underneath. But don’t drive it afterwards , run it 15 - 30 minutes with windows open and not being in the car. I drove mine after and the chemicals got me very sick
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Does it blow warm air, or does the blower stop?
Two entirely different issues...
