New spark plugs and coils
Old Mar 13, 2024 | 06:44 PM
m00nd0gy's Avatar
GLK350 ML55 Ducati Porsche
I think I am due for new spark plugs and maybe new coils. I have 138,000 miles on my 2011 GLK305.
What you all think of the attached link.
https://www.walmart.com/ip/CarBole-6...585/1692058974
Old Mar 13, 2024 | 06:57 PM
Mmr1's Avatar
2013 glk 350
You’re just asking for trouble using that set. Fcp euro has a lifetime warranty on everything they sell.
The plugs are an unknown brand, you don’t know the electrode composition, or life, im sure they are not platinum-iridium that last 130000. They might fail at 15000.
The heat range, operating temperature of the plug is exact within a narrow range, it is unique to each motor. The improper plug temperature could foul the plugs fast or melt them . Even known brands can have build issues. Those could , and will probably be a nightmare.
The coils, could be the wrong voltage output, but nobody is going to test them, they play not give voltage needed for proper combustion.
PASS , you don’t want to experiment! Labor is a big part of this job. I think it will cost you double using them.
Old Mar 13, 2024 | 08:12 PM
m00nd0gy's Avatar
I checked FCP Euro, I think they are the same as carpart.com.
Old Mar 13, 2024 | 08:48 PM
m00nd0gy's Avatar
Here are 2 spark plugs up for considering
https://www.autozone.com/external-en...702/417820_0_0
Old Mar 13, 2024 | 11:34 PM
habbyguy's Avatar
2011 GLK 350 4Matic
The coils that MB built into your GLK will outlast the car, and work as well 20 years from now as they do today. The ones you're looking at? Who knows? But I've seen an awful lot of people end up building "new and exciting problems" into their cars with aftermarket coils.
And the plugs? High-quality plugs are cheap. Gas is expensive. Go NGK or Bosch or other "serious plug". Save the money you were going to spend on lesser coils and spend it on a transmission fluid swap and really do the car a favor. ;-)
Old Mar 14, 2024 | 04:04 AM
PACIFICMAN's Avatar
2022 GLC 4Matic
Habby, I must disagree about the MB / Beru factory coils. I had one fail catastrophically, literally burst, arc out and disable an entire cylinder bank. Shortly after I sorted that mess out a second factory coil failed in less dramatic fashion. I do agree that the spark plug job is Very laborious and "tricky" due to space concerns. If I had proactively changed out the coils when I did the plugs(Bosch) I would have avoided the subsequent coil failure episodes. I switched to the upgraded Bosch units, not costly, from FCP Euro.
I also agree absolutely stay away from obscure off brands. Its not money you save its money you don't spend today...
Old Mar 14, 2024 | 05:27 AM
Mmr1's Avatar
2013 glk 350
The coils do last, why replace them if they work properly. Sure some fail, so replace the failed unit.
Old Mar 14, 2024 | 05:49 AM
m00nd0gy's Avatar
Good advise, I will change spark plugs first, using Bosch. Thanks guys!
Old Mar 14, 2024 | 06:39 AM
Mmr1's Avatar
2013 glk 350
You do need to replace Plug Boots ! At 70000 I didn’t , I just did plugs . I was running on 4 cilinders until I replaced them all !! You really can’t drive on 4 cylinders !
read the condition of your plugs ( research it) I had one burning cold so I replaced that coil hoping it had only weak spark . If plugs are not burning light brown and clean , try a new coil for that plug. And use a name brand like Bosch, not China Shiney
Old Mar 14, 2024 | 06:49 AM
m00nd0gy's Avatar
What made you change boots? My car has slight rough idle with brakes on. When shifted into neutral it goes away. Otherwise runs smooth. Plugs were changed at 70k miles.
Old Mar 14, 2024 | 07:34 AM
Mmr1's Avatar
2013 glk 350
I changed plugs, my mechanic said I should change the boots . I said no, not knowing how they age and don’t like being removed replaced. After he did the plugs I drove home on 3-4 cylinders. I barely made it home. I was running perfectly before I changed the plugs . New boots fixed it. I did also change one coil where the plug, one plug, was darker , indicating it was running cooler. Don’t ever use Chinese parts on your car, they- auto zonesss are selling junk that costs mechanics and customers countless costs in agony. It’s Chinas secret war. Once I went through 7 starters , then changed brands. The mechanic did it free, but he lost, and I lost 8 days ! FCP euro guarantees everything, you can actually return used oil and brakes !! Buy genuine parts from a real supplier. When I was buying plug Autozone ordered the wrong ones , to really know your plug you must use the VIN and for anything you order . There are to many variations today
Old Mar 14, 2024 | 07:48 AM
Mmr1's Avatar
2013 glk 350
If you used quality plugs before you might not need plugs. They last 100000+. It could be a boot , one coil , an injector, or something else. A bad ring or Valve or carbon in the intake !! Locate the one cilinder and check that plug and a few others and read their condition. If you put in that Chinese Surprise, you likely would have a mess.
Old Mar 14, 2024 | 08:12 AM
Mmr1's Avatar
2013 glk 350
A good local mechanic with a good scan tool should find the cause. most any auto store runs codes for free ( to sell parts) maybe they could find it , for a few $. It could be easy 6 different things , or more .
first try injector cleaner , Alcohol in the gas like Heat, several cans , and highway driving .
And a different brand of gas! With bad or real old gas I’ve needed a gallon of alcohol !
Old Mar 14, 2024 | 09:26 AM
m00nd0gy's Avatar
I am planning to keep my GLK for another 3 years max.
Old Mar 14, 2024 | 10:33 AM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I'm sure you're convinced by now that the highly questionable "complete kit" is a bad decision, both financially and longevity-wise.
Very lengthy discussions in various motorcycle groups about spark plugs have a general consensus:
Beware of buying NGK plugs, except from a reputable parts store. IOW, don't buy from eBay or some Amazon hosted store, because NGK fakes are notoriously sold as the real thing. There's even a website about identifying fake NGKs - and there are many YouTube video on the subject.
So, if you do decide to go NGK, only buy from a local nationwide parts shop. (like AutoZone, NAPA, OReilly, etc).
The only place I'd buy from, online-wise, would be FCPEuro. And as far plugs go, I'd only use Bosch.
Old Mar 14, 2024 | 11:09 AM
Mmr1's Avatar
2013 glk 350
I read about the ngk fraud and how to spot them on YouTube, I got fed up with Autozone and being worried just went to MB. Yes the right plugs of proper heat range and construction are critical . A cheap Chinese might even break and ruin a motor !
Old Mar 14, 2024 | 05:43 PM
m00nd0gy's Avatar
Anyone try Autolite Iridium Ultra Laser spark plugs AI 5702 , is a fit for GLK350
Old Mar 14, 2024 | 09:54 PM
calder-cay's Avatar
What's the attraction with the Autolite?? Cost?
I looked up our 2014 GLK350 Base, and Bosch at the local auto parts are 13.50 USD each. I'd consider that minimal cost (bargain?), considering the mileage one gets out of these plugs.
The only other plug they have that fits our GLK, are Champion for 10 USD each. The price difference doesn't entice me to *not* use Bosch.
Old Mar 14, 2024 | 11:16 PM
m00nd0gy's Avatar
I guess you can't answer the question.
Old Mar 14, 2024 | 11:59 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I’m in general agreement with the consensus here that Bosch or NGK spark plugs are the default choices. Mercedes uses one or the other at the factory.
But I also believe the Autolite double platinum plugs would be suitable. I’ve used them in other applications. You probably have the M272 engine in a 2011 GLK350. In a later GLK with M276 engine I would not use anything but the factory plug in an MB box because of specific design match to the engine. The M272 is not so picky.
The coils “should” last longer than the 70k miles, but the truck is 13 years old, so maybe not. To check them takes an oscilloscope, which is unreasonable for most DIYers. I like the comment about looking for plugs that are not running light tan to find weak coils. I recommend the Bosch coils because a number of people have had the factory Beru coils blow out.
Now - the plug boots. Change them all. They can be purchased separately from the coils. Time and heat are the enemy of plug boots. Over time and heat soaked in the head, they lose their dielectric properties. They can look fine and be electrically leaky.
My 2 bits. Good luck with it.
Old Mar 15, 2024 | 06:59 AM
m00nd0gy's Avatar
Thank you. I purchased new plug boots plus the Autolite Iridium laser plugs on sale for under $10 each, the packaging says made in Mexico. That is my concern. I used NGK at about 70k miles, seem ok, now they're $17 each.
I found this on ebay, they sell bosch also. I don't like their shipFrom origin. Box says made in germany. Difficult to trust anyone these days.
https://www.ebay.com/itm/33501859840...3Avlp_homepage
Old Mar 15, 2024 | 08:19 AM
m00nd0gy's Avatar
Here is Popular Science spark plug review article. Then I sourced local availability and price. Something to do during retirement, I have too much free time ...
https://www.popsci.com/gear/best-spark-plugs/
Old Mar 15, 2024 | 11:30 AM
MBKLUE's Avatar
Yikes:
Ship from origin does seem like a bit of a red flag. Maybe Bosch has them made in China these days but that wouldn't make me too happy either. That's not to bash China. They produce junk and some very high quality stuff and everything in between but at times it seems a lottery.
Old Mar 15, 2024 | 12:44 PM
Mmr1's Avatar
2013 glk 350
Ship from origin, only the Chinese use poor English . Counterfeit are known in spark plugs . Stop trying to save and expose yourself. If it’s to cheap there is a reason. Also Iridium are the proper plug metal, not other metals . I use Fcp euro for everything, I’m seeing to much crap Chinese stuff mess up mechanics and customers . And I’m not in the business
Old Mar 15, 2024 | 01:06 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Why would a part marked "Made in Germany" be "Located in: Long Hua,GuangDong, China"?
