2010GLK350 4 MATIC 5160 DIAG CODE
I'm getting a 5160 code, online it says it's park brake related, but my autel says
WC55 (Yaw rate sensor for lateral and longitudinal acceleration) has an electrical fault.
Any ideas?
Any ideas?
I recently researched this same issue, based on a failure that - in some other models, at least - could be due to a bad "yaw rate module". I was never able to definitively identify where it might live in a GLK though. I did read that it had been incorporated into the ABS module (the electrical part that screws onto your ABS pump / distribution block). FWIW, in other models, it lived in (IIRC) the rear floorboard, maybe under / near the seat?
Which is a long-winded way of saying "if you DO find out that there IS a yaw rate sensor in a GLK, please let us know". ;-)
In front of the larthe"seam" ill callbit for lack of better words, is the lowest part so MUCH water there, foam is sogged. Behind the seam is the 2 studs where the sensor bolts on. It was wet there also. Not sure where the water is coming from, that will be a later day i guess. Hope this helps.
SUCCESS!!! All lights off. Cruise etc working perfectly. Still trying to figure out the water ingress.
Now a new problem... I have been searching but no luck finding anything. I will make a new thread.
