COIL PACK OR CAM SHAFT POSITION SENSOR?
Old Mar 12, 2025 | 01:36 AM
JamesMBZ's Avatar
1990 500SL, 1990 560SEC, 2010 ML63, 2007 SL550
Hello all, 2014 GLK350 4matic, 58k miles. Screenshot of codes attached. P2094 & P2092, P0348 & P0393 , then P030585 & P030685.
Are the Position sensors causing the misfire?
It's in dreaded limp mode.
Thoughts, fixes?
Thanks in advance!
Old Mar 12, 2025 | 07:28 AM
Mmr1's Avatar
2013 glk 350
What is the history of the vehicle , 58000 miles and all those codes! 3 cylinders misfires, coils last a lot longer than that . Is it a Flood vehicle?
Old Mar 13, 2025 | 12:42 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
4 short circuits. 2 to ground, 2 to positive. I would suspect a damaged wiring harness or connector.
OR
Oil in the wiring harness from the cam adjuster magnets or the cam position sensors. Pull the connectors to the magnets and sensors. Look for oil. It shouldn’t be there and can cause all sorts of damage.
