GLS Class (X166) Produced from 2016 to 2019
Secondary/Intercooler Coolant Change/Flush
Old Mar 14, 2023 | 03:22 PM
cp0007's Avatar
2010 S63
Anyone have any documentation about flushing/changing the coolant on the secondary/intercooler cooling system (small tank under the engine cover) on a 2018 GLS450? Cannot seem to find anything about the best way to do this...
Old Nov 5, 2024 | 10:50 PM
bbqBiker's Avatar
550i
any luck finding answer?
Same question for the 2017 GLS550...you have any luck finding a DIY for this service? Thanks!
Old Nov 6, 2024 | 04:21 PM
cp0007's Avatar
2010 S63
What I wound up doing was disconnecting one of the hoses from the reservoir to the pump and drained the reservoir and the hose. Then filled with distilled water and ran it for a bit, drained again. Did the drain and fill I think about 4-5 times...the water was almost clear. Then added coolant mix back in and ran it a bit to get an accurate level and topped off.
hope this helps
