GLS Class (X167) Produced 2020 to present
Wireless charger
Old Apr 14, 2021 | 08:56 PM
Behrad Torabi's Avatar
mercedes gls580
Wireless charger
Anybody else have an Iphone 12 pro max and the wireless charge works for 10 seconds then stops? I even tried taking my case off and it has same issue. Wonder if there is an issue with the wireless charger in my car or the iphone 12 pro max just doesn’t fit right.
Old Apr 15, 2021 | 10:53 AM
Bob Burket's Avatar
17 AMG CLS63S; 21 AMG GLS63
I have an iPhone 12 Pro Max with Apple leather case. The phone charges flawlessly even w/ case on. Silly question: dod you try rebooting your phone?
Old Apr 15, 2021 | 04:52 PM
MS580's Avatar
GLS 580
I have an iPhone 11 Pro with an Apple leather case. Before I bought the 580, I set the phone in the cradle to make sure that it would work. It worked great! After the paperwork was done and I was getting ready to leave the dealership, I set the phone in the charger and nothing happened. It absolutely refused to recognize the charger. The young lady "concierge" who was showing me how the car worked set her phone in the charger and it worked, so I figured it was some problem with my phone. Internet research revealed that when a phone fails to charge you should shut it completely off and turn it back on again. Did that, and it worked. No more problems with the phone charging.. Try it. I hope it cures your problem.
Old Apr 18, 2021 | 07:39 AM
benzdrummer's Avatar
2014 GL 550
My 12 does the same thing on my 63–starts charging—then within 10 seconds claims objects are in the way. Even the charger on my 580 was slow at best. I guess this is an IPhone issue not M.
Old May 17, 2021 | 05:31 PM
Argentexan's Avatar
GLE 450
I have the same issue. I have the iphone 12 pro. I have tried charging with no case, the magnasafe case from Apple, no difference. I can't charge it using the wireless charge. I took it to the dealership and they told me they tested it with different phones and it worked with all of them so they couldn't replicate the issue. Annoying.
Old May 17, 2021 | 06:19 PM
Eaton's Avatar
Top Answer: 1
https://www.theverge.com/tldr/2017/1...h-the-iphone-x
Old May 18, 2021 | 11:36 AM
ksalno's Avatar
2011 Audi A4, 2014 E63S Wagon, 2020 GLS 580
Not sure if this is the same problem but I have a wireless charging stand at home I use for my iPhone X. It worked fine for a while and then it wouldn't charge one day. I played around but couldn't get it to work. So I ordered a new one. That arrive and it also wouldn't charge the iPhone. So I did some searching on the Apple forums and discovered this is an issue with the iPhone and the only way to fix it is to do a full power down and restart. It works every time iPhone refuses to charge on my home wireless charger. I haven't run into the problem with my 580 but maybe you want to try a power off reboot?
Old May 18, 2021 | 03:32 PM
c4004matic's Avatar
17 E43; 21 GLS580
My S20 note with otter box does not fit.
Old May 19, 2021 | 12:19 PM
jomama's Avatar
2021 GLS450
neither does the iphone 12 (pro) max with a modest size case. i didn't want a max for a few reasons (couldn't find a non-max 12 pro), and this is just another one. i really wish the compartment was roomier, or that the charger was somewhere more convenient.
Old May 19, 2021 | 01:22 PM
c4004matic's Avatar
17 E43; 21 GLS580
I think the optional center charger for the rear seats will fit essentially anything.
Old May 19, 2021 | 04:55 PM
darlop's Avatar
a
The wireless charger is basically pointless for me since you still have to plug in for AndroidAuto and Carplay. And when the phone is plugged in there is no place to put it so you just have to wedge it in the cupholder. The whole center console is poorly designed and not thought out.
Old May 19, 2021 | 05:07 PM
c4004matic's Avatar
17 E43; 21 GLS580
It might be me, but a fail to understand why I spent 120k on one of the most technologically advanced vehicles in the universe that has nav, telephone interface and terrific multiconnected audio system to skip all that to use android or apple auto. DONT GET IT🤔
Old May 19, 2021 | 07:32 PM
darlop's Avatar
a
Because Google Maps is better.
Old May 19, 2021 | 08:08 PM
mercedes gls580
I Use Waze for speedtraps
Old May 19, 2021 | 08:49 PM
c4004matic's Avatar
17 E43; 21 GLS580
On fact, no. Only the search portion. The actual navigation portion of the car is better.
Old May 19, 2021 | 08:51 PM
c4004matic's Avatar
17 E43; 21 GLS580
I put in my addresses using mercedes connect most of the time.
Old May 20, 2021 | 12:32 AM
darlop's Avatar
a
Google now tells you about speedtraps too (they bought waze).
Old May 20, 2021 | 12:34 AM
darlop's Avatar
a
No it really isn't. Nothing is better than Google's real time traffic info. I can't count how many times it has saved me time by routing me thru what seems like a silly detour. Sometimes I don't listen and I always end up regretting it. No other system is that good.
Old Nov 9, 2021 | 06:16 PM
hmarsili's Avatar
GLC COUPE 300E
I'm having the same issue. Did anyone solved it after replacing the part or any other way? I'm having the issue with a new GLC COUPE. Starts charging and a few seconds later stops with an error related to an 'foreign object'.
Old Nov 9, 2021 | 06:17 PM
Eaton's Avatar
Top Answer: 1
There is software update the dealer can apply to fix the issue now.
Old Dec 4, 2021 | 03:39 PM
instarand's Avatar
‘21 GLS 450, ‘20 Ford Raptor, ‘20 Mazda Miata, ‘21 A35 AMG.
good to hear. Having the same problem in my ‘21 450. Both my phone and my wife’s phone will charge for a few seconds then disconnect. Been happening since new. At first service I’ll ask dealer to check.
