C32 Vs. WRX STI
E63
the reason you see more consistent "better times" with Evo's is gearing. the Sti gearing is not condusive to 1/4 mile runs. 1st gear about 30 mph, 2nd 58mph, 3rd I forget about 78, 4th 98 and 5th not sure on. That's alot of shifting to finish the 1/4 with alot of room for mistakes and time lost to shifts.
LOL sorry no straight cut gears for me, this car is my daily driver , well as much as it can considering I have 3 other cars. I am considering Andrewtech's longer 1-4 gear upgrade. For right now I will do the RWD conversion and see how I like it.
E63
I know what you mean about the daily driving. But, I found it's not any harder to drive...just sounds like you are breaking stuff. It really does work best though when you are using it for what it is made for Oh and if you are wondering if the whine is loud...yea, kind of noisy.
20+ to list......
Accord,
With what you said about the STi's, when one is equipped with an intake and turboback exhaust, it will hardly be in the 12s. I've driven both on and off the road, which is because I own both. Even though mine is an WRX, but its setup is beyond what an average STi owner can afford, fully built Cosworth motor w/ JUN sequential manual (only one unit used on public roads as far as I know), T67 turbo running 28psi on pump, plus other bolt ons with nitrous, car put down 596whp on C16 and managed a 10.8 1/4 run with full interior and a cage. I am not trying to show off my fully prepped drag/street car, but just to let everybody on this board who don't quite know about Subaru's to get some correct info on how STi runs on the tracks. As some others have said, you need to have at least an intake, full exhaust, fuel pump upgrade, and reflash plus a good driver to get the car into the mid 12s. On the other hand, the EVO with a turboback exhaust, intake, minor fuel system upgrade, reflash, and a boost controller, can get the car into the high 11s with a good driver. I am not saying I am a good driver, but with the above mentioned plus intercooler piping upgrade, I managed a 11.83 quarter. For cornering, the STi's and WRX's have an uncorrectable understeer no matter what you do about suspension tune ups; however, the EVO's are famous for its point and shoot capabilities, with some small changes, it's even better, understeer is non exisitent. On papers, the STi might have better hp and tq, but in reality, the EVO is a superior car to the STi, in both straight line and cornering.
Accord,
EVO's and STI's are great cars.. but the EVO is a bit ahead of the curve.
I would disagree as I pointed out before this comparison is a ringer. The Sti's stock turbo is smaller than the Evo's and that's not taking into consideration the Evo9 which uses a 10.5 cm exhaust housing. So it's not some type of magic that the Evo's make more power than Sti's with similar or less mods. Now the other half of my car club is Evo's so I have worked and driven them. Yes they are very nimble but I believe it's a bit too go cartish and alot of guys get into trouble with that. The Sti's understeer is easily addressed, I know since I have mine dialed in for me perfectly. Camber 1.5 front, upgraded steering bushings with a anti lift kit which also as a by product gives positive steering response. I kept my stock sway bars since a stiffer setup like most guys use on Sti's and Evo's wander on uneven or rough roads. I could if necessary use a stiffer adjustable REAR sway bar and the car would definitely be on the over steer side but I don't need that for street duty. All that said I am currently using a FP green which is a 49 trim wheel with only a 7cm housing and I am defintely making more power than a fully bolt on and tuned Evo. Why no magic, just .5 liters larger engine, or like 350z's with only 8 psi half of what we run and 1/3 of what evo's run and make more power. It's just the fact more displacement = more power. All in all both cars are great but each has it's pros and cons.
#32
Location: Afghanistan / South Florida / Camp Lejeune, NC
2008 BMW M6, 2008 Ducati 1098, 2008 Ducati Monster S2R1000, 1971 Ducati Scrambler
Accord,
If you want to talk about reality, the reality is Mitsubishi cannot even afford to compete in the WRC, and when they were competing they were in essence the Minardi of WRC.
A Porsche 911 GT3 vs. a Ferrari 360 Moden vs. a NSX-R vs. vs. a Ferrari 355 F1 vs. an STI vs. an Evo vs. a Skyline: http://www.************/car-movies/09...Subaru-Evo.htm
So much for an Evo wiping the floor with an STI on the track.
That's reality.
#33
I forgot about DCCD, mainly because I don't use it. For stret duty the auto setting is fine but ACCORD is right if you put it in full lock understeer is negligible.
#34
It seems like every day some kid in an STI wants to street race me. For some strange reason, the EVO owners around here appear a few years older and act appropriately more mature. It's easier to respect the car when the driver is not performing a ricer fly-by followed by crazy weaving through traffic.
#35
I have never, I repeat never met or seen an Evo owner who wasn't some wigger any older than 16 or 17, and I see several everyday, whereas I mabye see 1 STI every few weeks, if that. I've even had one Evo owner flash me gang signs .
This is even reflective on the respective online communities, you go somewhere like IWSTI and nearly every STI owner is either a college student or working professional, compare that to EvolutionM where nearly every Evo owner is a teenage old punk kid wHo Talkz like dis.
I don't know about you, but whenever I think of the stereotypical Evo owner, I think of that old internet classic "Icey Hot Stuntaz" or whatever it was called.
You guys all know exactly what i'm talking about.
#36
Wonder what an Atom would do to these. Probably wouldn't be much of a contest as the Atom is insane fast and made for the track. I so want an Atom to drive to work.
#37
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
I see punk wigger Icey Hot Stunna owners of both STI's and EVO's, and then I also see mature enthusiasts who turn their cars into fire breathing road-beasts. Its pretty easy to figure out who's who. Take for instance, the other day I'm at the local liquor store with my gf picking up a couple bottles of wine. I'm sitting in my Beemer about to fire it up, and I hear this thunderous groan across the street. A white EvoIX, lowered on black rims with all the proper goodies including a nice CF panel protecting the rear bumper from melting pulls up into the spot right next to me. Normally I'd expect a hard look, maybe a challenge to a race, anything, but the guy shut it down and jogged right into the liquor store. I liked the Evo so much I hung around to check it out, nice brake kit, really sweet choice of rims, obviously very well sorted, and the color was verrry nice. The guy comes out and I said, "nice Evo dude, good job." He thanked me and hopped right back in, fired it up and crawled out of the parking lot and up the street. All kinds of people drive these cars, not just ricers.
#39
#40
here is a stage 2 car.. (pulley, ecu and headers) running mid 11's (notice the trap speed) NO drags
http://videos.streetfire.net/search/...2156f0372a.htm
I personally like Evo's but there are wayyyyyy too many of em around here.
#41
20+ to list......
I'm sorry, but you're absolutely wrong about having uncorrectable understeer, that's just ridiculous considering the fact that a simple alignment can can get rid of any and all understeer and even give you more than enough oversteer should that be what you want. You don't "own both," you own a highly modified 2002 WRX, which is in absolutely no way, shape, or form similar to a 2005 or 2006 STI. Your WRX may have some crazy sequential transmission, but it doesn't have DCCD which is standard on all STI's and easily eliminates virtually all understeer.
That's reality.
That's reality.
#42
Trust me no one was offended but I did offer the reasons why the Evo is better at least in some people's eyes. As for ricers in Sti's well kids must be making more money since to step in a Sti you need 30k give or take before taxes, registration, insurance etc....the same could be said about the Evo. Don't get me wrong the Sti is cheap compared to some of the cars I owned but is in no way easy to buy for a kid. Most of the guys in the car clubs I am a member of make me look like a kid and I am 33. We have doctors, lawyers and senior citizens who are owners. LOL all that said I have had a few kids in Sti's and Evo's harass me, but in the same note I have had plenty more "GANSTA" types in bimmers and benzs bug me too. It's quite a scene when you get pulled up on by a M3 or E 55 with a kid driving, hat turned to the side and upside down. I always have to stifle my laughter, and here in NY this is the norm.
#43
2005 Mitsubishi Evo VIII MR
I drive an evo, and I hate being classified as a youngster (although I am only 26) and I absolutely HATE being classified as a street racing punk. Sucks to hear that you guys get so much grief from Evo OR STI owners....like previosuly stated before, there are many different types of owners. I get heat from STI owners all the time, as well as some Evo owners....and then there are the genuine motorsports loving, apex strafing owners who love the track beast they bought for $35k or less.....
Anyway, good kill...keep it safe on the streets...
#44
WELL PUT!!!
#45
2008 C300 Sport & 2008 E320 Bluetec
Bone stock STI's will do 0-60 in 4.5 seconds and consistely run mid-high 12's in the 1/4 mile all day long with a half decent driver, all you need to be in the low 12's is an intake and a TBE, which i'd say a majority of STI's have. You really had no chance at all.
The only way a C32/55 has a chance against an STI, is at a roll already at highway speeds, in any other situation, forget about it.
#46
ML350 '06
I had a chance to race an STI 2 days ago but the kid wouldn't go. We were driving for a few miles so he had plenty of opportunities and he would catch up to me and then slow down. I think he was just checking me out. His car sounded modded and had all the tach gauges but he wouldn't race. I was looking forward to seeing how he would do against my E55 - just curious. I have had some runs with Evo's with my C55 and that was fun! Especially the last kid who pulled over and was bumbed b/c his mods he just had done didn't beat me...although it was very close until the end. I like both of these cars STI & EVO!
I was talking to a buddy of mine and we're thinking about getting a beater Jap car to work on. Especially since the hp gains will be much cheaper than modding my E55. But then, I'd love to see what my car with a fully staged Renntech setup would be like! Hmmmm? My wife hates this new hobby of mine!
