My ML 500 is stuck!!!
Old Aug 5, 2005 | 06:46 PM
twenty2's Avatar
ML 500 gone, ML 320 gone, C230 kompressor, & Hummer H2
My 2002 ML500 gear shift lever is stuck in the park position. I can override it by taking the gear shifter cover off and taking a screwdriver to take it out of the park position. But, when I have to park, I have to leave it in Neutral with the parking brake on. Could anyone tell me what the heck is wrong? No indicator lights are on at all. The truck drives fine. ITS JUST STUCK IN THE PARK POSITION GEAR SHIFTER WHICH IS LOCKED.
Old Aug 5, 2005 | 07:36 PM
Kar don's Avatar
Mercedes-Benz
This is kind of common on the 02 ML's, try turning the ignition on and off a few times.
Old Aug 5, 2005 | 07:39 PM
twenty2's Avatar
okay... let me try that... be right back..
Old Aug 5, 2005 | 07:43 PM
twenty2's Avatar
tried that... and it still stays stuck. Any other suggestions????
Old Aug 5, 2005 | 08:22 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
There is I believe a solinoid that allows it to go from park to where you want it. This solinoid may not be releasing or has failed. Have it diagnosed at a dealer.
Old Aug 5, 2005 | 09:15 PM
twenty2's Avatar
looks like I'll have to do that. Thanks to everyone......
Old Aug 6, 2005 | 03:06 AM
ML God's Avatar
Your shifter is bad.....there is a solinoid in there to release it from park. Easy to change just remove your center console. Only 4 bolts hold the shifter in
Old Aug 6, 2005 | 10:00 AM
sosh's Avatar
Well, its good to see you back. !!!
Old Aug 6, 2005 | 11:34 AM
twenty2's Avatar
thanks for the update MLGOD. Great to see you again!! I was hoping you would be checking this post. Do you know approx. how much this part costs? I'm out of my warranty right now. I have 61000k on the ML500.
Old Aug 6, 2005 | 12:34 PM
ML God's Avatar
I know it isnt cheap.....I will check on Monday
Old Aug 6, 2005 | 01:45 PM
twenty2's Avatar
sounds good... thanks again.....
Old Aug 7, 2005 | 01:02 AM
2mbusa's Avatar
1999 Mercedes Benz SL500 & 2009 E350 4Matic Wagon
Thumbs up Stuck shifter
GLAD ML GOD IS BACK -- don't ever let them beat you down again!!!
