Anyone install lowering springs on the rear?
Old Feb 7, 2006 | 10:54 AM
paulzale's Avatar
If so, how difficult? Any special tools? Thanks!
Old Feb 7, 2006 | 11:56 AM
pointman's Avatar
a car that can't do the throttle reset.
did you try a search?
Old Feb 7, 2006 | 12:31 PM
paulzale's Avatar
Yes, it sounds like a spring compressor and standard tools....
I just want to make sure it is not that bad.
Old Feb 7, 2006 | 01:06 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
what springs are you going to do? and dont forget to lower the front from the torsion bar
Old Feb 7, 2006 | 01:23 PM
paulzale's Avatar
Got eibachs used from someone. I have already lowered the front, very easy to do. Actually, I just changed my right front wheel bearing, which is alittle involved but not too bad. Have to remove the 'spindle' to have the hub and bearing pressed out and then the new ones back in. I was having a loud noise that sounded like tire noise and got very bad turning. I figured it was the wheel bearing and it was as the noise is gone. I lowered the front and didn't have time to tackle the rear yet.
Old Feb 7, 2006 | 01:58 PM
pointman's Avatar
pretty straight forward.. especially if you can change a bearing by yourself. just make sure you have the right kind of spring. your current ones are either round or flat. the new springs have to be the same. to check, just look at the end of the current spring.. the end will be flat or be round like the rest of the spring.
also, please tell me you had the truck off the wheels when you lowered the front end.
Old Feb 8, 2006 | 08:42 AM
paulzale's Avatar
Um, not at first, but then I did jack it up to lower the remain portion. I think I went a few turns before lowering, I also had to bring the left side back up a little as I lowered too much.
Any reason why it needs to be off the wheels for lowering the front end?
Thanks for the advice on the springs.
Old Feb 8, 2006 | 01:47 PM
pointman's Avatar
no problem.
i ask, cause if it is on the ground when you lower the front end, the torsion bar is gonna go on you prematurely.
