Changed cabin air filter today, Big difference.
Old Jun 30, 2006 | 04:38 PM
nsfkid's Avatar
98 ml 320, MGB GT V8 (FACTORY)RHD
Changed the cabin air filter today on my 98 ML320, the amount of old leaves and debris that came out when the filter was removed was remarkable.
See attached photo, The old and new filters beside each other, (and this was after tapping out the loose stuff!)
There is a noticeable improvement in airfow now. My ML has approx 60,000mi It most likely has not been been changed in a very long time.
Mike,
Attached Thumbnails Changed cabin air filter today, Big difference.-ml-cabin-air-filter.jpg-mod.jpg
Old Jun 30, 2006 | 06:15 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
What is the right way of inserting the cabin filter?
I just replaced mine too at 92K miles on my 00 320. It had been never replaced before and the difference in airflow is quite noticable.
I followed instructions from this web-site.
http://www.whnet.com/4x4/cabinairfilter.html
which took me to a step by step instruction link
http://www.keysolutions.com/m-class....ent&AutoFramed
What puzzled me is the picture attached below from that site. When I pulled down my old factory installed cabin filter, it was installed just the opposite of what this picture shows...the periferal sponge border showd up on the other side (towards the center console) and not towards the passenger side door, as this picture seems to hint.
I went ahead and installed my new cabin filter the way the olde one came out, but this picture keeps haunting me...
Can anyone confirm, the right way of inserting the filter. The MB part doesn't come with any instructions or arrows on it.
Attached Thumbnails Changed cabin air filter today, Big difference.-cabin.jpg
Old Jul 1, 2006 | 01:03 AM
nsfkid's Avatar
The picture does show the correct installed direction for the filter.
The plastic "tang" toward the seat. The filters are directional.
Mike,
Old Jul 1, 2006 | 12:09 PM
Tommy_s4's Avatar
ML320, Looking for my S4
Ok where is the cabin airfilter, it is not the air intake for the engin right?
Old Jul 1, 2006 | 12:45 PM
nsfkid's Avatar
Correct, click on the links posted by - mihir d. The filter is located on the passenger side under the dash. There is a plastic cover that has a 12v outlet on it. Just pull this panel straight down, Its held on buy four metal spring clips. You will then see the black plastic cap that holds the filter in.
To change the filter takes 5 min max, no tools required. (on the early models)
Mike,
Old Jul 1, 2006 | 02:08 PM
pleubner's Avatar
W163 W164 R230
The bosch link doesn't seem to be working for me! ... so I thought I'd post this as well.
... shows the direction of the airflow.
Attached Thumbnails Changed cabin air filter today, Big difference.-acabin-ait-filter.jpg
Old Jul 9, 2006 | 04:40 PM
mihir_d's Avatar
Based on the pictures in this thread, I believe in you...
Mike,
I turned around my filter and re-installed it.
Below is the picture of my old factory installed filter....the protruding stuck leaves in the filter will give you an idea of how it had been installed - clearly the other way around. So, did it come installed wrongly from factory???
Can such a mistake happen at the factory? I am not surprised, if it did happen, it went un-noticed in QA..
Attached Thumbnails Changed cabin air filter today, Big difference.-picture.jpg
Old Jul 9, 2006 | 09:12 PM
AsianML's Avatar
2007 E63
I cleaned mine a week ago too. Huge difference. Although I don't think mine was as dirty as yours.
I posted pics here.
http://pointedthree.com/disc/forums/...sts=14&start=1
Old Jul 9, 2006 | 09:41 PM
MBfan89's Avatar
wats a good web site i could buy a cabin filter for ml ml 320
Old Jul 12, 2006 | 05:43 PM
BOERNE ML320's Avatar
2001 ML320
Mine was just as dirty at 41,000. But our ML previously belonged to a smoker. I cleaned it out and sprayed some odor nutralizer on it for now.
The dealer wants $35 for a replacement. A good tip for an aftermarket supplier would be sweet!
Old Jul 13, 2006 | 03:51 PM
Stiggs's Avatar
2003 CLK55
I posted pics here.
Asian.........can you post the pics here? I can't see them on that other site.
Old Jul 13, 2006 | 09:30 PM
AsianML's Avatar
2007 E63
I deleted the pics from my computer. I think you have to sign up to see pics. Sorry. :o
Old Jul 14, 2006 | 12:07 AM
OttoBon100's Avatar
'11 C300
Stiggs. Just looked at his post. He only posted one picture ("Did I put the cabin air filter in right?") and it is very much like the one mihir d posted which is the proper way to install the filter. It wouldn't help more than that.
Old Jul 15, 2006 | 10:51 PM
AsianML's Avatar
2007 E63
You sure about that? That's not the only pic I posted, but it wouldn't help him much.
Old Jul 16, 2006 | 08:45 AM
OttoBon100's Avatar
'11 C300
Just looked again. That is all that is there.
Old Jul 16, 2006 | 09:01 AM
AsianML's Avatar
2007 E63
You looked at the wrong thread then. But anyway, it still wouldn't help Stiggs as much.
Old Jul 16, 2006 | 09:05 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I get all my MB and Toyota OEM parts from www.autohausaz.com - great prices! I think I paid $19 for a Bosch OEM cabin filter for my C43 through them.
Old Jul 16, 2006 | 11:46 AM
OttoBon100's Avatar
'11 C300
Sorry AsianML. Didn't know you had posted twice - same subject. I was looking at the July 7 post. The July 1 post you did only had two pictures of the dirty filter after removal which wouldn't have helped in determining the position of the filter when installing. "pleubner" did post detailed instructions in your July 1st post that are very helpful though for those installing one. Guess this is all moot now though. I think we know how. Thanks.
