Codes PO300 '99 ml320 cat ?
Old Nov 29, 2006 | 08:10 PM
sdanville's Avatar
ml320
120,500 miles on the 1999 ML320.
At 100,000 I replaced the
Spalrk Plugs
Crank Shaft position Sensor
Fuel Filter and Pump
at 120,000 miles it started misfiring on medium acceleration.
then idle rough. I could restart at stop lights and the idle would smooth.
Reading the forums I thought Mass Air Flow sensor. cleaned it a couple times then bought a new one. No change.
Seems better in warmer temps. If I drive really really easy its usable but not too safe if I need to scoot.
Auto Zone guy said codes PO300 multi cyl misfires then reads off every single cyl. PO301 to PO306. He said wires or plugs. I dont buy that. all at once ?
I am waiting for my back ordered Cat converter thinking restriction. Im all ears if anyone has fixed this. steve.
Old Dec 3, 2006 | 11:21 PM
mbtech360's Avatar
Ive seen once or twice, cats so clogged up it causes a missfire. From what it sounds like its a MAF, but i wouldnt replace it till the cats are replaces. The plugwires could be bad too, but when those go the motor seems only to have a skip not a complete missfire. Id wait to see if the cats fixes it.
Old Dec 4, 2006 | 08:54 AM
sdanville's Avatar
ml320
Misfires continued
Thanks for the reply. The more I read the more it seems a plugged cat would effect the plugged side not mis fires on all cyl.
1) I replaced the Mass Flow Air Sensor. Bought a new one off ebay for $100.
No change. But then I disconnected the battery for a night and it seemed better.
2) Then I jump started a 90 year old man in the bank parkiing lot which I read we shouldnt do. (jump start cars with Mercedes).
3) I reset the transmission brain ( per forum instructions ).
I noticed it starts with a bit of a rev like it use to again,,
My ML320 doesnt feel perfect, but I am getting along. The streets are snow and ice here so I have not done anything close to agressive accleration.
The reason I reset my transmission, I made a stop on a street..put it in reverse to back into a driveway...nothing happened..then I put it in drive and nothing happened...after a few seconds with traffic coming down on me fast it engaged in drive.
I really want to be an optimist..but I am really ready to ban Mercedes from my contenders in my next purchase. Just bought my wife an Equinox. not even close to the enjoyment of driving the ML320. But I trust it. So It will be driven to Florida this month.
Old Dec 10, 2006 | 09:14 AM
sdanville's Avatar
ml320
UPDATE: Dealer installed catalitic converters. When i brought it in he asked "anything else?" i said it misses but want to see what the cats do before i commit. 4 hours later he comes in the waiting room and says they found a vacuum line malfunction. $80. labor. I was just happy to be done and have it idling good. I will never know if it was the cats, the computer reset, or a vacuum line.
Old Dec 17, 2006 | 11:57 AM
sdanville's Avatar
ml320
I spoke too soon on the smooth idle. Ordered ANOTHER mass air flow sensor. I checked my resistance on one bank of ignition wires. all in the same range but dont know where they should be exactly. maybe one faulty thing snowballed into 3 or 4. the spark plug replacement helped. The MAS helped. The new cats helped. but once in the last ten drives i went to pull ou in traffic and took a minute to get up to 60 MPH. Embarasing and dangerous. Thats when I ordered another MAS.
Old Dec 17, 2006 | 04:14 PM
YuCrew's Avatar
'99 ML430, '84 380SL, '04 XC90, '12 X5
Vacuum Line
Do you know which line they replaced? Glad to hear your problems are slowly getting resolved.
Old Dec 24, 2006 | 05:26 PM
sdanville's Avatar
ml320
vacuum line location.
The service tech was vague- real vague.
He said...
"The mechanic insulted whomever was working on this because in the back of the engine there was a vacuum line kinked or routed wrong and he either replaced it or corrected. It was in the back of the engine hard to see ".
I have taken the plastic engine cover off and looked with a flashlight and mirror over and over hoping to find a split vacuum line or one disconnected.
I drove it 150 miles in the last 24 hours. ITs fine warmed up on the XWay but at stop lights it misses terrible. I am taking my reliable Chevy to Florida tomorrow. In two weeks I will be at it again...trying to cure the Mercedes.
Old Jan 20, 2007 | 05:51 PM
esco7497's Avatar
hey i am having a problem one of my cats is cracked the first one on the passenger side what did they charge you to replace the cats
Old Jan 20, 2007 | 05:55 PM
sdanville's Avatar
ml320
Free Free Free
Recall for the 1999 ML320. savings...$3000 said the dealer.
Old Jan 21, 2007 | 06:01 PM
esco7497's Avatar
need info
hello do you recall how much you paid for the cat to be done. I am currently having the same problem i need to make an appointment with the dealer this week
Old Jan 21, 2007 | 06:06 PM
sdanville's Avatar
ml320
Free Zip -0- Nada
The Cats Cost me -0- NADA , zip, Nothing.
Recall for my 1999 ML320.
I have both done for FREE.
I said to the service guy when leaving...guess I saved a couple grand eh ? He said more like $3,000.
