ML320 hood won't open
O boy! truck comes in for P/S problem and I go to pop the hood and the hood won't open. Funny....
I check the cable where the lever is and it looks good. I remove the cable and pull using a vise grip and still won't pop. I have another guy play with the cable while I lissen for where it's working. At this point I have removed the inner fender well on the drive side to see if I can reach the cable. I can get my hand on it and pull but still doesn't open. I can feel it moving while the other guy pulls fron inside the car. I hear it near the latch but I can not reach it. The question is how do I get the hood open ( with out cutting a hole in it! ) I think that the cable might have broken at the latch. I am stumped and don't know where to go with it. Any ideas would help a lot Thank you Bill |
Originally Posted by Highend repair
(Post 2048156)
I check the cable where the lever is and it looks good. I remove the cable and pull using a vise grip and still won't pop. I have another guy play with the cable while I lissen for where it's working. At this point I have removed the inner fender well on the drive side to see if I can reach the cable. I can get my hand on it and pull but still doesn't open. I can feel it moving while the other guy pulls fron inside the car. I hear it near the latch but I can not reach it. The question is how do I get the hood open ( with out cutting a hole in it! ) I think that the cable might have broken at the latch. I am stumped and don't know where to go with it. Any ideas would help a lot Thank you Bill Looking at that you have 2 post. Not meaning to be rude in anyway, Have you pull the triangle lever from the 3 point star emblem in the front? You will never see this triangle lever if you have never opened a ML hood before. |
hehe ya tried that first.
Well made a call to a friend ( MB tech ) and below the latch there is a plastic plate. Popped that off and gained access to the latch. From there standard latch operation. Will replace latch and wire to fix problem. ( seems it broke the cable from the latch being to hard to throw. over stressed, Looks bent, hit or abused? ) Turned out to be the cable end had broken and come out of the latch. BM- PS: only a n00b here :) |
To get to that cover you had to open the hood.
So how did you get the hood open? |
