Check Engine Light comes on with abrupt braking
My check engine light comes on if I abruptly brake. Then it goes away after sometime (4-5 days). Any idea what could be wrong. I am planning to buy a code reader, any suggestions which one should I buy?
Thanks a bunch.
P0100 - Mass or Volume airflow circuit
P0170 - Fuel Trim (Bank 1)
P0173 - Fuel Trim (Bank 2)
P0130 - O2 Circuit (Bank 1 Sensor 1)
10135 - O2 Heater Circuit (Bank 1 Sensor 1)
I just changes the plugs and fuel filter. Why would trim codes show up. Should I talk to dealer for this?
I want to know what can I fix myself. I am an engineer and have done some work on small motors.
If there are any procedures available please point me to them.
Thank you much.
Pradeep
Truck is running fine with a bit of power loss periodically. I an just concernt hat it might cause damage to other parts in the system.
I asked the local dealership to change it. They are charging $675 to replace it.
I have recently changed spark plugs and fuel filter.
thanks
Pradeep
Are these easy to fix?
thanks
Pradeepp
I finally chnaged the MAF sensor and the fuel trim code are still there. I am guessing that it is some leak somewhere. Is my understanding right?
thanks
Pradeepp
Can someone please suggest what can I do to improve the feel of acceleration.
