Temperture indicator in Dash of ML500
Old Dec 13, 2002 | 04:40 PM
m500's Avatar
03 ML500
Question Temperture indicator in Dash of ML500
What is the average temperature should be for ML500?
My 03 ML500 is exceeding 100 degree when A/C is on during heaving traffic. Is this too high, the average temperture on my ML500 is just close to 100 degree. I thought it should stay under 90 degree at all time.
Old Dec 13, 2002 | 04:51 PM
JJunkins's Avatar
2000 ML 320
Your temp gauge should be just over 80. That's were mine hangs out at nearly 100% of the time. You might want to go have it checked out. The may be some debris in the line or the thermostat may be going out. Also look for mud on on your thermostat. If you don't know where it is, just hose off the underside of your engine.
Old Dec 15, 2002 | 01:37 AM
ghitos73's Avatar
ML320
I was wondering about that too ... the temperature gauge on mine is always a little above 80 degrees.
