CAN bus location 99 ML320
Old Jun 23, 2008 | 04:47 PM
fujioko's Avatar
1999 ML320
Hello Folks,
I'm new to the forum. My background is automotive electronics and electrical systems.
Anyway one of our engineers ask that I find a suitable location to monitor the CAN signals in a 99 ML320. Specifically they asked that I find CAN “B”.
Currently we do not have a manual on the test vehicle and I cant seem to find a good location to tap into the CAN bus. My current information is the twisted pair I’m looking for is brown/red
Can anybody offer an idea ?
Jim
Old Jun 23, 2008 | 10:14 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
there *should* be Can Bus signal available at the shifter... in one of the harnesses that run through that area... if you look for information on how to retro fit an aftermarket nav system into a non factory equipped vehicle, you should find the canbus wiring as you need to interface for the navigation unit...
Old Jun 24, 2008 | 08:38 AM
fujioko's Avatar
1999 ML320
Hello,
Thanks for the reply!. I did a quick search on this forum and located a post pertaining to NAV system retrofitting. Unfortunately the link within the post seems to be dead. I double checked the technical publications and discovered no publication is available.
Anyway I’ll dig into the shifter area and see if I can find the CAN bus harness. Hopefully I’ll be able to get the consul apart without damaging anything. This vehicle appears to be built with higher standards than a Saturn.
Thanks again!
Jim
Old Nov 6, 2008 | 02:30 AM
blanquillo's Avatar
ml270cdi
Originally Posted by fujioko
Hello,
Thanks again!
Jim
Hello,
Did you find the CAN bus?
I need know where is it.
Tank you
