headlight changes colors
Old Dec 17, 2009 | 12:36 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
For pass couple of nights my 00 ML55 passenger side headlight is changing to different color.. Purplish one night then it is blueish the next. Is my bulb going or the ballast?
Old Dec 17, 2009 | 09:11 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely the bulb
Old Dec 21, 2009 | 12:41 AM
poonamt93's Avatar
V8 Ford
No,your bulb is not going.
There is no power going to the light assemblies when you have your keys in the off position, when you have your lights off, and you are not modifying the connector's wiring.. so it is pretty safe.
Just take note and be careful pulling the decorative molding on the front/bottom of the headlights.. It is easy to break or lose something if you are not careful..
Old Dec 21, 2009 | 12:18 PM
sosh's Avatar
Bad advice. He says that when its on it changes color has nothing to do with the key position or the wiring. There is no need to pull the molding. Believe that you have not a clue and this is not the first time. Perhaps your reading is deficient.
Old Dec 28, 2009 | 06:41 PM
fkong777's Avatar
How do you remove the HID bulb? do I have to loosen the hex bolts. I cant twist the bulb at all.
Old Jan 4, 2010 | 12:00 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I always loosened the nut and took the plastic trim off
Old Jan 4, 2010 | 02:56 PM
fkong777's Avatar
thanks that is such pain to just remove a bulb.
Old Jan 6, 2010 | 05:17 PM
55fanatic's Avatar
I dont think it could be any easier to change these bulbs, lol...
that is the only PITA part but I can do a full bulb swap in about 10 minutes, luckily you dont have to do it so often
