Brake light switch for 1998 ML 320
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
It is located at the top of the brake pedal arm. You may have to remove the panel below the dashboard for access. Changing the switch is very easy and should be obvious once you see the switch.
Mike
Mike
