1999 ML headlight went out...ugh
Old May 1, 2012 | 02:00 PM
rnp614's Avatar
1999 ML
I was wondering is this a home fixer or do I have to go to a shop for this? Is this a good time to try and get higher output lights or stick with stockers? Wheres a good source? Partsgeek?
Old May 2, 2012 | 11:52 AM
alphonsohall's Avatar
ML270CDI
I recently replaced the headlight bulbs in my ml with Osram higher output bulbs, i didnt need to remove the headlights to do this but the h/lights are easy to remove anyway, just remove the single screw on top and two 10mm nuts hidden behind the plastic strip at the bottom and the headlight comes out.
Old May 5, 2012 | 08:13 AM
Stiggs's Avatar
2003 CLK55
I changed my own headlight bulb and if I can do it, anyone can do it! The driverside was hard because it is a really tight space to get into. Save yourself the money and DIY!
Old May 5, 2012 | 12:16 PM
rnp614's Avatar
1999 ML
I ended up going to an autozone with my ipad and bought some silverstar ultras (i think?) and used their tools to put them in. The lights are brighter than stock I just wonder how long they'll last!
