Where does it go
Wedged between the frame and body, right rear is a dust cover part # A 163 988 00 35 which according to MB parts on line is a dust cover. It is a black dome that has three bolt covers Where did it come from?
Thanks John |
EPC shows nothing for that part number. Are you sure that is the right number?
where does it go
The part number is A 163 988 00 35 Google search reveals it is a dust cover. But from where?
pics?
Weird...It's a valid number in the database but it doesn't show up in the catalog. +1 for pics...
2 Attachment(s)
This is the closest I could get to what you are referring to. It protects the adjustment screw for the torsion bar/front spring.
Odd
Originally Posted by Maj. Dundee
(Post 5456564)
I assume it is part of a kit/assembly or discontinued. roy@pelicanparts.com . |
Originally Posted by PelicanParts.com
(Post 5468883)
That part does not come up in the catalog.
I assume it is part of a kit/assembly or discontinued. roy@pelicanparts.com . What catalogue are you referring to? |
Answer
(Post 5470152)
The part and its number comes straight from EPC net, M/B on-line parts list.
What catalog are you referring to? We have access to a lot catalogs, but in this case I was referring to the MB price catalog. If it was a valid stand alone part, it would have come up with a listing/price. Usually: * This means MB only offers it as part of a KIT or assembly. * The part is no longer available through MB. roy@pelicanparts.com . |
1 Attachment(s)
(Post 5472114)
Usually:
* This means MB only offers it as part of a KIT or assembly. * The part is no longer available through MB. roy@pelicanparts.com . If it was discontinued it would so state. Did you ever consider the possibility that it was mistakenly excluded from the price list? |
Where does it go
1 Attachment(s)
It is the plastic cover for the upper shock mount on the rear . Please see attached PDF . Figure # 75p
Cheers _PTEngineering |
You guys did all this work and the OP only posted twice, 15 days ago, with no pictures which would have made all the difference in Id'ing this part.
Mike |
Answer
(Post 5472276)
M/B is very precise when it comes to parts and their numbers. If it was included in a kit, the part would look exactly like #68 or #70.
If it was discontinued it would so state. Did you ever consider the possibility that it was mistakenly excluded from the price list? cap 1639880035 $12.00 roy@pelicanparts.com . |
Originally Posted by Mike's ML
(Post 5472713)
Mike Yes I understand that Mike, but the tail end of this thread was about parts and their nomenclature and nothing more. |
