New issues after brake light switch replaced
Old May 13, 2013 | 12:40 PM
redbird's Avatar
2001 ML320
I'm looking for some advice on how to proceed with my 2001 ML320. I'm not sure if I should keep trying to fix it or if it's just time to let it go.
Last week I had the brake light switch replaced at the dealership (open recall), because my brake lights would stay on continuously. It fixed the issue with the brake lights, but ever since then the BAS/ESP light keeps coming on. I took it back to the dealership and they swore up and down it had nothing to do the the switch replacement, and instead wanted to charge me $1200 for a new hydraulic booster.
Additionally, since they had the car, it's having more and more trouble starting up. It turns over but takes a long time to actually start, longer every day it seems. Dealership is blaming the fuel filter and wiring, another mechanic said it might be the fuel pump.
Now, I can see the slow starting problem happening right after the switch replacement being a coincidence, but with the BAS/ESP light I'm just not so convinced. Has anybody had similar experiences?
Old May 13, 2013 | 08:13 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Remove the brake light switch that they installed (it should be blue in color) and follow the instructions in the pdf.
File Type: pdf
Old May 14, 2013 | 03:41 PM
redbird's Avatar
2001 ML320
Thank you!
Old May 14, 2013 | 08:47 PM
Di that do the trick?
Old May 15, 2013 | 09:50 AM
redbird's Avatar
2001 ML320
I have not had a chance to try it out yet
Honestly the starting issue is getting so bad I may just try to trade it in before it completely dies on me
