ML350 Homelink - near zero range
Hi all - I just got as 2010 ML350 and the Homelink, despite many repeated attempts to program and reprogram, will not give off a strong enough signal to open the garage door (has a Chamberlain opener) from more than about 3 ft from the closed door. Also, it works only sporadically. I have corresponded with Homelink, Chamberlain and my dealer about this and tried essentially everything they suggested. We even tried building a parabolic reflector to put around the Chamberlain antenna to amplify the signal (no effect). Has anyone seen a similar issue - and if so, did you find a solution?
pbalaw
pbalaw
